Standard: 0
Security Suite: 0
Security: 48
System title: 7E A0 07 03 D1 53 0B BB
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
TX: 13:43:46 7E A0 07 03 D1 93 07 7D 7E
RX: 13:43:46 7E A0 20 D1 03 73 47 14 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
TX: 13:43:46 7E A0 6B 03 D1 10 44 C5 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 7E A0 07 03 D1 53 0B BB 8A 02 07 80 8B 07 60 85 74 05 08 02 06 AC 12 80 10 06 64 83 CA A7 42 48 8D 5E 72 EF 30 EF A4 A2 34 BE 23 04 21 21 1F 30 90 E1 D0 CB 8F 15 21 69 F6 34 AB D3 5C 12 17 AD D7 00 40 E3 E5 C5 1E D2 8A 78 9A 82 AC A1 16 DE 7E
RX: 13:43:46 7E A0 2D D1 03 30 57 EF E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 00 06 F4 7F 7E
FAILED
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 821, in parsePDU2
_GXAPDU.parseUserInformation(settings, cipher, buff, xml)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 332, in parseUserInformation
_GXAPDU.parseInitiate(False, settings, cipher, data, xml)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 559, in parseInitiate
_GXAPDU.parse(initiateRequest, settings, cipher, data, xml, tag)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 406, in parse
raise GXDLMSConfirmedServiceError(ConfirmedServiceError(data.getUInt8()), ServiceError(data.getUInt8()), data.getUInt8())
gurux_dlms.GXDLMSConfirmedServiceError.GXDLMSConfirmedServiceError: ServiceError Initiate Error exception. Application reference 6
During handling of the above exception, another exception occurred:
File "c:\DLMSGURUPython\main.py", line 133, in main
reader.initializeConnection()
File "c:\DLMSGURUPython\GXDLMSReader.py", line 392, in initializeConnection
self.client.parseAareResponse(reply.data)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\GXDLMSClient.py", line 619, in parseAareResponse
_GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 657, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "C:\Users\\AppData\Local\Programs\Python\Python314\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 828, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
gurux_dlms.GXDLMSException.GXDLMSException: Connection is permanently rejected
No reason is given.
REPR: GXDLMSException('Connection is permanently rejected\r\nNo reason is given.')
ARGS: ('Connection is permanently rejected\r\nNo reason is given.',)
TX: 13:43:46 7E A0 07 03 D1 53 0B BB 7E
PS C:\DLMSGURUPython>
Using the example from the GuruX website, I get :
py -3.14 main.py -S COM23 -L LGZ
gurux_dlms version: 1.0.203
gurux_net version: 1.0.23
gurux_serial version: 1.0.21
Authentication: 0
ClientAddress: 0x10
Standard: 0
No reason is given.
How exactly should I use the example. I'm probably doing it wrong.
Hi, I believe you are…
I believe you are talking about the Landis+Gyr E360 meter. Do you try to communicate with the optical probe or via a TCP/IP connection?
The settings vary between different connections.
Hi Kurumi. It's an optical…
Hi Kurumi. It's an optical probe, and I do get some comms back and forth. I do not really know DLMS ,so I do not know what the logs mean.
Hi, Select Landis+Gyr as a…
Select Landis+Gyr as a manufacturer. Then change authentication level to None and
interface from HDLC to HdlcWithModeE.
The baud rate is 300 7E1.
You should be able to connect now.
Like I said, I'm able to get…
Like I said, I'm able to get traffic back and forth, so I don't think changing the comms settings will work.
Authentication : 6
ClientAddress : 104
ServerAddress : 1
InvocationCounter : 0x90e1d0cb
Authentication: 6
ClientAddress: 0x68
Initializing secure association...
Standard: 0
Security Suite: 0
Security: 48
FAILED
No reason is given.
Using the example from the…
Authentication: 0
ClientAddress: 0x10
Standard: 0
No reason is given.
Hi, Your block cipher or…
Your block cipher or authentication key is different from what the meter uses. You need to check that.
