  3. From Where To Start
From where to start
By Bhavjinder Singh , 20 June, 2018
I have to create android app which will read DLMS based meter data. Pls suggest me from where i can start. Im new in dlms protocol, first i have to prepare the communication between meter and mobile device. I'm not able to create the channel between meter and mobile through optical strobe
Regards
Bhavjinder Singh
Bhavjinder Singh
8 years 1 month ago
Select serial port first
Code is returning select serial port first in toast
8 years 1 month ago
From where to start
You need optical head or USB to serial port converter to read your meter. I believe you don't have that installed at the moment.
Bhavjinder Singh
8 years 1 month ago
Im able to read data
Hi..
I'm able to read data, but now problem is how can convert byte array return by meter as a reply to actual data. If class id is 8 then i have to convert byte array to decimal value for datetime.
Bhavjinder Singh
8 years 1 month ago
Mine problem is to interpret data returned by the meter.
Administrator
8 years 1 month ago
From where to start
You should check those:
http://www.gurux.fi/Gurux.DLMS.Client
Bhavjinder Singh
8 years 1 month ago
Getting data
Hi ..
Pls help me, i got the data in byte array for meter serial number and Clock. But both parameters have data type returned by meter is 'OCTETString' so now how can get the actual value, because for MSN is a ascii value and clock parameter is in decimal.
Bhavjinder Singh
8 years 1 month ago
Scaler unit
how to read Scaler unit of any particular parameter
8 years 1 month ago
Reading data
Date time is returned in OctectString. You need to convert it to the dateTime format.
GXDLMSClient.ChangeType -method.
Scaler and unit are in attribute index 3 of register object.
Bhavjinder Singh
8 years 1 month ago
Thank you!
First, Thank you!
Im able to get actual meter's datetime. But not able to figure out where is scalar and unit values.
Bhavjinder Singh
8 years 1 month ago
readObject(obj, it);
if (obj.getObjectType() == ObjectType.CLOCK) {
Object obj1 = GXDLMSClient.changeType((byte[]) obj.getValues()[1], DataType.DATETIME);
Log.i("Datetime", String.valueOf(obj1));
is this the right way? to get byte array of response
8 years 1 month ago
Reading data
If your object is clock it's done automatically.
GXDLMSClock c = new GXDLMSClock();
readObject(obj, 2);
Bhavjinder Singh
8 years 1 month ago
Reading of register
I want to read register parameter just say "Cumulative Energy – kWh" ...
I have initialise GXDLMSRegister("1.0.1.8.0.255"), im getting response from the meter but im getting NONE for the unit.
8 years 1 month ago
Reading of register
Try to read that with GXDLMSDirector. If the result is the same, your meter is set the unit to NONE.
Bhavjinder Singh
8 years 1 month ago
Failed to recieve reply in given time
hi mikko
Im using GXDLMSDirector to read meter paramter, im getting this reply from meter in the trace:
29/06/2018 12:37:06 PM
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="20" />
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
29/06/2018 12:37:13 PM
<HDLC len="9" >
<FrameType Value="53" />
<DisconnectRequest>
</DisconnectRequest>
</HDLC>
Pls help
regards
Bhavjinder
8 years 1 month ago
Try to change client address to 10.
Bhavjinder Singh
8 years 1 month ago
Connection is permanently rejected. No reason is given.
Hi Mikko... below is the response im getting :
<HDLC len="9" >
<Snrm>
</Snrm>
</HDLC>
02/07/2018 12:13:41 PM
<HDLC len="1E" >
<TargetAddress Value="20" />
<SourceAddress Value="1" />
<FrameType Value="73" />
<PDU>
<Ua>
<MaxInfoTX Value="256" />
<MaxInfoRX Value="128" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
<HDLC len="43" >
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<MechanismName Value="Low" />
<CallingAuthentication Value="4142434430303031" />
<InitiateRequest>
<ProposedConformance>
</ProposedConformance>
</InitiateRequest>
</AssociationRequest>
</PDU>
</HDLC>
<HDLC len="2C" >
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="01" />
</ResultSourceDiagnostic>
<ConfirmedServiceError>
<Service Value="01" />
<ServiceError>
<Initiate Value="IncompatibleConformance" />
</ServiceError>
</ConfirmedServiceError>
</AssociationResponse>
</PDU>
</HDLC>
<HDLC len="1E" >
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
Pls. help me...
Regards
Bhavjinder Singh
Bhavjinder Singh
8 years 1 month ago
im using GXDLMSDirector
Bhavjinder Singh
8 years 1 month ago
Scaler unit
Im getting scalar:1, unit:None what does this means.. im reading Instantaneous Frequency
Bhavjinder Singh
8 years 1 month ago
getting error "invalid structure" exception on readObject
if (obj instanceof GXDLMSProfileGeneric) {
try {
readObject((GXDLMSProfileGeneric) obj, 3);
GXReplyData reply_data = new GXReplyData();
byte[][] temp;
temp = mClient.read((GXDLMSProfileGeneric) obj, 2);
readDataBlock(temp, reply_data);
} catch (Exception e) {
e.printStackTrace();
8 years 1 month ago
Are you reading profile generic or something else? Please, describe the problem better. I can't help if you copy only a few lines from the example.
Bhavjinder Singh
8 years 1 month ago
Im reading profile
Im reading profile FOR INSTANTANEOUS PARAMETERS... first im reading capture object
but im getting error on the above line as "invalid structure"
8 years 1 month ago
What meter are you trying to read? Can you post reply data from the meter? I can check it.
Bhavjinder Singh
8 years 1 month ago
Hey Mikko,
Hey Mikko,
Mine problem is I dont know how to read profile generic.. below is the code i have write:
try {
//readObject((GXDLMSProfileGeneric) obj, 2);
byte[][] temp;
temp = mClient.read((GXDLMSProfileGeneric) obj, 3);
for (byte[] it : temp) {
byte[][] temp1 = mClient.read((GXDLMSProfileGeneric) obj, 2);
for (byte[] it : temp1) {
readDataBlock(temp1, reply_data);
Pls guide me ...i will be very thankful to you
Regards
Bhavjinder Singh
  • vGYWbHeKACYPlTkuxT
  • BrandonKar
  • voAVzKKjRXqwsE…
  • ElliottWew
  • Denniscresy
