  3. Delphi Client Example
By progzero , 17 January, 2018
Hello. I compiled the example and decided to try to connect with the meter.
Parametrs:
Gurux.DLMS.Client.Example.Delphi.exe -r ln -c 48 -s 1 -h 192.168.1.115 -p 10005 -P 12345678 -a Low -C None
A connection error occurs. By log file it is clear that the address of the server takes 1 byte:
7E A0 07 03 61 93 69 47 7E
But my address should occupy 2 bytes and the command should look like this:
7E A0 08 22 03 61 93 B3 AE 7E
How to specify in the example the dimension of the server address? In the program GXDLMDirector, the dimension is not specified and it works correctly.
Thank you!
8 years 6 months ago
Add client and server parameters:
-s 2177 -c 30
progzero
In reply to Delphi Client Example by Kurumi
I've already tried, not connection:
Connected.
Send SNRM request:
Disconnecting from the meter.
Error! Source addresses do not match. It is 1. It should be 2177.
But in log file correct request:
<- 10:50:51\t7E A0 08 22 03 61 93 B3 AE 7E
progzero
Here is the answer:
7E A0 1F 61 22 03 73 59 F1 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
In debug:
server = false
index = 32
readLogical = 0
readPhysical = 1
logical = 17
physical = 1
source = 1
target = 48
We have found an issue if address size is two bytes.
http://www.gurux.fi/node/6576
It's now fixed. Get the latest version.
  • Kak_maKr
  • Marciaannem
  • Scottstike
  • rcprociG
  • helloworld
