  3. Register Value In Gurux.DLMS.CPP Missing
Register value in Gurux.DLMS.CPP missing
By jankrejci , 5 January, 2018
Hi, Im trying to understand Gurux.DLMS.CPP example app and have some misunderstanding.
Im run example server app and trying to read his values with Gurux Director, but for Register 1.1.21.25.0.255 Im getting empty /means nothing, not null or something that/ value. Doing Im something bad or its only missing the command "pRegister->setValue(123456)" in the server code?
8 years 10 months ago
If your value is static (it don't change) you can set when you create the object. If that is dynamic you can update the new value on PreRead.
jankrejci
Thanks, Im now able to create object with static value.
About dynamic values - what means PreRead? I found some objects of this name in the code, but I dont undestand them. I suppose, that i must call modified instance of this object before reading the register, right? Sorry about this stupid question, I havesome knowledge about DLMS, but i dont fully understand how works some objects, i have only excepts of dlms specification.
You can update value dynamically like this:
void CGXDLMSBase::PreGet(std::vector<CGXDLMSValueEventArg*>& args)
std::string ln;
for (std::vector<CGXDLMSValueEventArg*>::iterator it = args.begin(); it != args.end(); ++it)
(*it)->GetTarget()->GetLogicalName(ln);
if ((*it)->GetTarget()->GetObjectType() == DLMS_OBJECT_TYPE_REGISTER &&
&& ln == "Change to Register LN")
CGXDLMSRegister* pRegister = (CGXDLMSRegister*)(*it)->GetTarget();
