  3. Proposed Conformance Using HighGMAC
Proposed conformance using HighGMAC
By AndreasAtPowel , 19 September, 2017
Hello
We have an application where we previously used version 8.2.0.3 of Gurux.DLMS. We then had the following code:
var gxdlmsClient = new GXDLMSSecureClient(true, 0x01, 0x01, Authentication.HighGMAC, authenticationSettings.UniqueSecret, InterfaceType.WRAPPER);
gxdlmsClient.LNSettings.SetConformanceBlock(new byte[] { 0x00, 0x1F, 0x1F });
gxdlmsClient.MaxReceivePDUSize = 0x00C8;
gxdlmsClient.Password = authenticationSettings.UniqueSecret.ToByteArray();
gxdlmsClient.Ciphering.SystemTitle = authenticationSettings.SystemTitle.ToByteArray();
gxdlmsClient.Ciphering.Security = Security.AuthenticationEncryption;
gxdlmsClient.Ciphering.AuthenticationKey = authenticationSettings.AuthenticationKey.ToByteArray();
gxdlmsClient.Ciphering.BlockCipherKey = authenticationSettings.UnicastKey.ToByteArray();
This week we have updated the version of Gurux.DLMS to Version 8.5.1709.1201. We see that we no longer can use gxdlmsClient.LNSettings.SetConformanceBlock. So instead we are setting the following property:
ProposedConformance = Conformance.Action |
Conformance.EventNotification |
Conformance.SelectiveAccess | Conformance.Set |
Conformance.Get | Conformance.InformationReport |
Conformance.MultipleReferences |
Conformance.BlockTransferWithAction |
Conformance.BlockTransferWithSetOrWrite |
Conformance.BlockTransferWithGetOrRead,
But when we try to run the application we get the error "Connection is permanently rejected. Authentication is required". Do you have any good ideas to how we can solve this problem?
Andreas
9 years 2 months ago
Hi Andreas,
Can you send trace from sent and received bytes? We'll check this ASAP.
AndreasAtPowel
This is what we have traced as sent/received bytes when trying to connect to the meter using version 8.5.1709.1201of Gurux::
char peer0_0[] = { /* Packet 1 */
0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x63,
0x60, 0x61, 0xa1, 0x09, 0x06, 0x07, 0x60, 0x85,
0x74, 0x05, 0x08, 0x01, 0x03, 0xa6, 0x0a, 0x04,
0x08, 0x4d, 0x4d, 0x4d, 0x00, 0x00, 0xbc, 0x61,
0x4e, 0x8a, 0x02, 0x07, 0x80, 0x8b, 0x07, 0x60,
0x85, 0x74, 0x05, 0x08, 0x02, 0x05, 0xac, 0x12,
0x80, 0x10, 0x3f, 0x29, 0x12, 0x76, 0x70, 0x00,
0x31, 0x18, 0x5c, 0x41, 0x55, 0x25, 0x16, 0x60,
0x1d, 0x12, 0xbe, 0x27, 0x04, 0x25, 0x21, 0x23,
0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xd3, 0x03, 0xda, 0xc9, 0x02, 0x36, 0x9b,
0xf9, 0x52, 0xfc, 0x36, 0x75, 0x4b, 0x70, 0xf9,
0x88, 0x0f, 0xe9, 0xc3, 0x8c, 0x68, 0xf6, 0xb6,
0x44, 0xdf, 0x9d };
char peer1_0[] = { /* Packet 2 */
0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x2a,
0x61, 0x28, 0xa1, 0x09, 0x06, 0x07, 0x60, 0x85,
0x74, 0x05, 0x08, 0x01, 0x03, 0xa2, 0x03, 0x02,
0x01, 0x01, 0xa3, 0x05, 0xa1, 0x03, 0x02, 0x01,
0x0e, 0x89, 0x07, 0x60, 0x85, 0x74, 0x05, 0x08,
0x02, 0x05, 0xbe, 0x06, 0x04, 0x04, 0x0e, 0x01,
0x06, 0x00 };
/Andreas
GMAC issue
We have fix this. I'm sorry about the inconvenience.
http://www.gurux.fi/node/6261
AndreasAtPowel
This seems to have solved our issue!
Thanks for the quick fix!
/Andreas
