  3. Support HLS Authentication For C++
support HLS Authentication for C++
By micgur01 , 13 September, 2017
I can see HLS support for to C++ at client side.
Is it supported at server side as well, can't see it in code.
Michael
8 years 10 months ago
Yes it's supported.
micgur01
support HLS Authentication for C++ for server side
Where is the relevant code? How to enable HLS at server side
for example HLS 5 - Galois Message Authentication Code (GMAC)
You don't need to do anything. Client decides what authentication level is used.
Get latest version.
micgur01
Hello Mikko Kurunsaari,
Using the latest version from today
I am trying work with DLMS_AUTHENTICATION_HIGH_GMAC
Got a coredump , see below
(gdb) p block->c3 >> 24
$1 = 1099511627708
AES is 255 array, so it crashed.
I've tried to change code to r0 ^= Shift((AES[block->c3 >> 24 ) & 0xFF], 8);
but then server side return InvalidConnection.
(gdb) r
Starting program: /home/micgur01/work/cleanDLMS/Gurux.DLMS.cpp/GuruxDLMSClientExample/bin/gurux.dlms.client.bin
InitializeConnection
Program received signal SIGSEGV, Segmentation fault.
0x000000000043d730 in CGXCipher::EncryptBlock (
settings=settings@entry=0x7fffffffd920, block=block@entry=0x7fffffffcc50)
at src/GXCipher.cpp:562
562 r0 ^= Shift(AES[block->c3 >> 24], 8);
(gdb) bt
#0 0x000000000043d730 in CGXCipher::EncryptBlock (
#1 0x000000000043dc16 in CGXCipher::ProcessBlock (settings=0x7fffffffd920,
input=0x7fffffffd9a0, inOffset=0, output=0x7fffffffd9a0, outOffset=0,
block=0x7fffffffcc50) at src/GXCipher.cpp:186
#2 0x000000000043e3ba in CGXCipher::Init (settings=0x7fffffffd920, aad=...,
iv=..., frameCounter=0, systemTitle=..., bufBlock=..., block=...)
at src/GXCipher.cpp:738
#3 0x000000000043ea8d in CGXCipher::Encrypt (this=this@entry=0x7fffffffd920,
security=security@entry=DLMS_SECURITY_AUTHENTICATION,
type=type@entry=DLMS_COUNT_TYPE_TAG, frameCounter=frameCounter@entry=0,
tag=tag@entry=0 '\000', systemTitle=..., plainText=..., encrypted=...)
at src/GXCipher.cpp:931
#4 0x000000000044c8ca in CGXSecure::Secure (settings=...,
cipher=0x7fffffffd920, ic=ic@entry=0, data=..., secret=..., reply=...)
at src/GXSecure.cpp:129
#5 0x000000000041661c in CGXDLMSClient::GetApplicationAssociationRequest (
this=0x7fffffffd520, packets=std::vector of length 0, capacity 2)
at src/GXDLMSClient.cpp:740
#6 0x000000000040596d in CGXCommunication::InitializeConnection (
this=0x7fffffffd430) at src/communication.cpp:688
#7 0x00000000004095cc in CGXCommunication::ReadAll (this=0x7fffffffd430)
---Type <return> to continue, or q <return> to quit---
By the way, only DLMS_AUTHENTICATION_LOW is working
others can not connect at all, and DLMS_AUTHENTICATION_HIGH_GMAC results coredump.
Could you please help?
Maybe need more settings to change, rather then authentication option?
Michael
Are you using GXDLMSSecureClient? What OS you are using?
micgur01
Gurux.DLMS.cpp example as is, yep CGXDLMSSecureClient
CGXDLMSSecureClient cl(useLogicalNameReferencing, clientAddress, serverAddress, authentication, password, interfaceType);
Linux Ubuntu(64 bit)
Michael
micgur01
Just check it on raspberry pi3 , Ubuntu Mate 32bit ( both client and server).
It looks ok, using GMAC - no coredump, print all info
Looks like 32/64 bit problem
it still problematic using server and client with different architecture, one 32 and other 64.
By the way , other HLS did not even start any object prints.
Michael
We run test using Fedora 64bit. I'll ask to install 64 bit Ubuntu and we'll try with that.
I'll let you know as soon as I have something.
Kernel Whoops
7 years 8 months ago
In reply to support HLS Authentication for C++ for server side by Kurumi
I've just experienced the
I've just experienced the same problem on Ubuntu 14.04 LTS 64 bits, g++ 4.8.4. Is there any solution for that?
Ubuntu 14.04 LTS 64
Do you have the latest version from Github? This should be fixed a long time ago.
Kernel Whoops
In reply to Ubuntu 14.04 LTS 64 by Kurumi
Ubuntu 14.04 LTS 64
I use the version downloaded from the master branch on October 16th this year.
KW
  • OlegVoiva
  • Martaepili
  • Vegazone-Alini
  • Curtistig
  • hollycx60
