  3. DLMS Protocol Wireshark Plugin / Protocol Analyser
By Aladdad , 31 July, 2017
Is there a open source DLMS Protocol Wireshark Plugin / Protocol Analyzer available to analyse a DLMS packet.
9 years ago
Not at the moment. We was planning it on a time, but DLMS protocol is so complicated that it's not easy to implement to Wireshark. We can show HDLC or WRAPPER frames quite easy, but showing PDU is causing more problems, because it can consist multiple frames. Showing just HDLC or WRAPPER frames makes no sense.
Aladdad
9 years ago
In reply to DLMS Protocol Wireshark Plugin / Protocol Analyser by Kurumi
Thanks Mikko.
Thanks Mikko.
andrebdo
8 years 4 months ago
> Is there a open source DLMS Protocol Wireshark Plugin / Protocol Analyzer available to analyse a DLMS packet?
I just published the DLMS protocol dissector plugin for Wireshark that I wrote:
https://github.com/andrebdo/wireshark-dlms
I hope it helps.
Petr Matousek
8 years 1 month ago
LUA dissector
You can also test LUA dissector for DLMS that we created for our research project. It partially supports HDLC encapsulation and TCP wrapper decapsulation as used by XMLDemo software. The dissector is freely available at https://github.com/matousp/dlms-analysis.
Best regards,
Petr
  • OlegVoiva
  • Martaepili
  • Vegazone-Alini
  • Curtistig
  • hollycx60
