  3. How To Write Voltage Threshold In HPL 3 Phase Meter
How to write voltage threshold in HPL 3 Phase Meter
By Goutam , 12 June, 2017
Can you please provide me some of sample code to write the over and under voltage threshold in HPL 3 Phase Meter?
Goutam
9 years 5 months ago
Do you mean Limiter object?
Goutam
In reply to How to write voltage threshold in HPL 3 Phase Meter by Kurumi
Both Register monitor and limiter object.
You just update wanted values to the objects and then write them.
Example:
GXDLMSRegisterMonitor r = new GXDLMSRegisterMonitor("OBIS Code");
r.Thresholds = new Object[]{(Uint16) 100, (Uint16)200};
Note!
The threshold must be the same type as the monitored object. If type is different error is returned.
com.Write(r, 2);
Goutam
In reply to Register monitor and limiter by Kurumi
I have tried with the example
string OBISCode = "1.0.32.7.0.255";//instantaneous parameter - Voltage OBIS code.
GXDLMSRegister VoltageReg = new GXDLMSRegister(OBISCode);
var VoltageRegData = grxComm.Read(VoltageReg, 2);
//Result : 23056//230.56
GXDLMSRegisterMonitor RegMonitor = new GXDLMSRegisterMonitor(OBISCode);
RegMonitor.Thresholds = new Object[] { (UInt16)23000, (UInt16)23100 };
grxComm.Write(RegMonitor, 2);
Exception: Access Error : Device reports a hardware fault.
Goutam
First check your authentication level. I believe you must use High.
Then make sure what is your data type of that register.
It must be the same.
Goutam
Following details found when I checked attribute index 2 of OBIS code 1.0.32.7.0.255
Access : ReadWrite
Index : 2
Type : Gurux.DLMS.Enums.DataType.UInt16
UIType : None
Please suggest me, how to fixed this problem.
Hi Goutam,
Can you send trace from send and received bytes to me by email? I can check this.
Goutam
I have attached received and send byte trace as follows, please check
Send
7E A0 25 03 61 76 EF 41 E6 E6 00 C1 01 C1 00 15 01 00 20 07 00 FF 02 00 01 02 06 00 00 59 D8 06 00 00 59 D9 86 1E 7E
Received
7E A0 11 61 03 96 EF 7E E6 E7 00 C5 01 C1 01 09 6D 26 7E
I also need bytes when you read that object. You are writing two UInt32 values.
http://www.gurux.fi/GuruxDLMSTranslator?pdu=C101C100150100200700FF02000…
Goutam
Voltage register read Trace:
Send
7E A0 19 03 61 54 39 98 E6 E6 00 C0 01 C1 00 03 01 00 20 07 00 FF 02 00 85 83 7E
Received
7E A0 13 61 03 74 85 83 E6 E7 00 C4 01 C1 00 12 5A 1A 5F 20 7E
Threshold write trace using UInt32:
Send
Received
Threshold write trace using UInt16:
Send
7E A0 21 03 61 76 03 33 E6 E6 00 C1 01 C1 00 15 01 00 20 07 00 FF 02 00 01 02 12 59 D8 12 59 D9 E6 14 7E
Received
9 years 4 months ago
You must write data using UInt16. Can you also read monitoredValue (attribute index 3).
Goutam
I have tried to read monitoredValue (attribute index 3) but that also throw exception
("Access Error : Device reports a inconsistent Class or object.")
Trace of monitoredValue
Send
7E A0 19 03 61 76 29 9A E6 E6 00 C0 01 C1 00 15 01 00 20 07 00 FF 03 00 D6 C1 7E
Received
7E A0 11 61 03 96 EF 7E E6 E7 00 C4 01 C1 01 09 29 2D 7E
I believe that you should ask from meter manufacturer from this.
I believe that this is not fully implemented.
selvamurugan
8 years 6 months ago
HPL EB METER TYPE: PPEM 26
Hi Kurumi,
I am using HPL EB METER.I am trying to format the data which are coming out from the EB meter serially.I can able to receive data from the serial terminal. I am using below-mentioned cmd to get the response.
Reuest:
7E A0 0A 00 02 04 01 41 93 22 D0 7E
Response
7E A0 21 41 00 02 04 01 73 1E 06 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
Here I would like to know which is indicating R, Y, B voltages, current, other parameters.
I am also searching some user manual on the internet
I have answered your question here:
https://www.gurux.fi/node/6967
