  3. Want To Read Data For Discovery RF Node
Want to read data for discovery RF node
By erdeepakcs , 30 May, 2017
Gurux.Serial
hello sir,
how can i read data using Gurux serial component for discovery RF nodes which are connected in meters. Because in discovery of node there is no fix length of data and also EOP is not there.
9 years 1 month ago
If there is no fixed length or EOP you must read data until all data is received.
Pseudo code is something like this:
serial.Send(Data to send, null);
do
serial.Receive(p);
}while(check that packet is received);
erdeepakcs
9 years 1 month ago
In reply to Want to read data for discovery RF node by Kurumi
hi sir
but when i set EOP to null and message is coming Either Count or EOP must be set.
9 years 1 month ago
Set count to 1 if you do not know how many bytes to wait. One byte is read then you can check is packet fully received.
erdeepakcs
9 years 1 month ago
hi sir
i have set count to 1 and i am still getting same exception message. what condition should i apply to check packet is received in gurux serial.
9 years 1 month ago
You must set it each time before calling Receive. We are resetting count after data is read.
Like this:
do
p.Count = 1;
serial.Receive(p);
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
