  3. Block Transfer
block transfer
By atulsawant , 1 March, 2017
Dear sir,
i want to transfer association objects in no of blocks but the XDLMSDirector doesn't send the next block command ..
what is the problem?
which changes are required?
The log is as follows:
09:55:52 Initializing serial connection.
09:55:52 Send SNRM request.
7E A0 17 00 02 0E D3 41 93 BD AD 81 80 08 05 02 00 80 06 02 00 80 F8 85 7E
09:55:52 Received data
7E A0 23 41 00 02 0E D3 73 54 2E 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
09:55:52 Parsing UA reply.<CR><LF>81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01
09:55:52 Parsing UA reply succeeded.
09:55:52 Send AARQ request
7E A0 47 00 02 0E D3 41 10 E1 69 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 3C 1F FF FF 42 F8 7E
7E A0 3A 41 00 02 0E D3 30 3B AA E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 3C 1F 00 71 00 07 B6 95 7E
09:55:52 Parsing AARE reply<CR><LF>61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 3C 1F 00 71 00 07
09:55:52 Parsing AARE reply succeeded.
09:55:54 --- Collecting objects. ---
09:55:54 Collecting objects
7E A0 1C 00 02 0E D3 41 32 BC 6F E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
09:55:54 Received data
7E A0 75 41 00 02 0E D3 32 DB 57 E6 E7 00 C4 02 C1 00 00 00 00 01 00 5D 01 0E 02 04 12 00 03 00 09 06 01 00 20 07 00 FF 00 02 04 12 00 03 00 09 06 01 00 34 07 00 FF 00 02 04 12 00 03 00 09 06 01 00 48 07 00 FF 00 02 04 12 00 03 00 09 06 01 00 1F 07 00 FF 00 02 04 12 00 03 00 09 06 01 00 33 07 00 FF 00 02 04 12 00 03 00 09 06 01 00 47 07 00 FF 00 EC 0A 7E
System.Exception: GetObjects failed. Insufficient memory to continue the execution of the program.
at GXDLMSDirector.MainForm.RefreshDevice(GXDLMSDevice dev, Boolean bRefresh)
at GXDLMSDirector.MainForm.Refresh(Control sender, Object[] parameters)
09:56:34 Send Keep Alive
Thanks and regards,
9 years 8 months ago
block transfer
You have one byte too much. You can check differences here:
http://www.gurux.fi/GuruxDLMSTranslator?pdu=C402C10000000000015D010E020…
