  3. Set a Value
set a value
By bahubali , 17 February, 2017
Dear sir,
I want to set any value using guruxGXDLMS director …..but the problem is that only GET button is enable when we are connect to meter and make a connection …
Why the set option is not enable (means the key in the top of GXDLMS director window).
Please let me know Which changes are required to unable that set button?
Thanks and regards,
Bahubali
9 years 9 months ago
set a value
Change value and write button is enabled. Only changed values are write back to the meter.
bahubali
set value
dear sir,
which values we have to change?
can you please provide example on this?
thanks and regards
set a value
Dear Sir,
Select object fro the tree. You see Object's values on the right side.
Change value to the text box and write button is enabled.
