  3. Fetch Live Data From Secure Meter Sprint 350 and Send It To Server Data Base
Fetch Live data from Secure Meter Sprint 350 and send it to server Data Base
By vivek22389 , 26 September, 2016
Hi ,
I am trying to get live data from secure meter sprint 350 to my remote server data base. In meter there is a RJ11 port is also available for communication . So can anyone help how can i get solution for this.Meter pic are attach in attachment.
10 years 1 month ago
mecure Meter Sprint 350
You can try to read this meter with GXDLMSDirector. Select "Indian standard" as manufacturer.
Then you need to set serial port settings and read meter. You can use Gurux.DLMS.Net, Gurux.DLMS.java or Gurux.DLMS.cpp to make your own app that sends data where you want to.
vivek22389
In reply to mecure Meter Sprint 350 by Kurumi
Secure Meter Issue
Hi Mikko ,
First of all thank you so much for your reply. I have tried to read data as per your suggestion by connecting meter with my laptop by cable (Pic : https://s13.postimg.org/whp4cj5d3/Secure_Meter_connection_cable.jpg) but not able to get data. So can please help me to get out from the issue.Is there any other way or issue is with that female to female cable(mentioned in pic) or any other reason.
Thank You
wordpress
Hi Mikko , I have been trying
Hi Mikko , I have been trying to fetch live data from secure meter as well and facing the same issue as vivek. I guess it has to be a cable issue. I am trying to procure other brand cable to see if that helps resolve the issue. Lets be patient :)
sarfaraj@tgtgas.com
8 years 10 months ago
In reply to Secure Meter Issue by vivek22389
is you received data from sprint 350
Dear vivek
may i know you received the data from 350 .and also know how you resolved the issue is any alternate way
sarfaraj@tgtgas.com
same issue on same meter .
Deart Mikko Kurunsaari
May i know the procedure of communication . three times data sent via GXDLMSDirector but unable to get any response from meter .
please rply on here or else on my email address.
Secure Meter Issue
Please, remove those loops from the cable. That might cause problems. Are you sure that your wiring is correct? I can say that it's very common that is not.
Meter Sprint 350
Hi Sarfaraj,
I don't know how your meter is configured, but you can try to start Start protocol from DLMS to IEC.
If the connection fails, let me know did you received any bytes from the meter.
Malay
7 years 4 months ago
I am also trying to read
I am also trying to read Sprint350.
It seems like serial port itself is not getting opened in my case. ioctl is not working.
Or
only sending from PC to meter is possible but no reply from meter.
If it is password protected what can be it's password?
Was the issue which Vivek has faced just a cable issue?
Hi Malay,
Hi Malay,
Please, if you have a new question, create a new topic. I'll answer your question there.
