  3. GURUX_DLMS Lib In IAR
GURUX_DLMS lib in IAR
By fighter , 14 January, 2016
is it possible to import GURUX DLMS library in IAR for msp430 or arm platform??
Did someone succeded with that???
I'm trying to import this in IAR, but i have problems with templates, since IAR uses EC++ runtime library which does not support templates...
Can someone help me with that??
Regards...
10 years 10 months ago
Without templates you have lots of problems. Design is based for templates. Are you planning to use 8, 16 or 32 bit processor?
We have ANSI C version but it is not Open Source yet.
fighter
thank you for answer...
We are planning to use it for 16 bit msp430, but it will be great to have possibility to port it for 32 bit arm cortex MCU at some later point of development...
This C version will be Open Source?
When do you plan to publish it??
Regards...
We will release ANSI C version after few months as Open Source.
Exact date is not solved yet.
fighter
thanks again...
It is possible to get actual version and maybe we can help with development or testing?
Regards...
I can send a proposal to you if you are interested.
You can send email to me. You can find my contact info from here:
http://www.gurux.fi/AboutUs
Profile picture for user mahsen
mahsen
7 years 3 months ago
For my dissertation I intend
For my dissertation I intend to read Electrical meter with dlms protocol and stm32l152 micro by c++ language
Can you provide me a library for keil or iar compiler?
Thank you so much
I believe that you need to use ANSI C version, STN32l152 don't have enough memory for ANSI C++.
You can use open source version:
https://github.com/Gurux/GuruxDLMS.c
