  3. Need To Parse DLMS Data (raw Byte Array)
Need to parse DLMS data (raw byte array)
By diptesh , 4 March, 2015
Dear All,
I am having a requirement in my .net application, where I am already getting the dlms command (ECS70 Clock) in raw byte format. Now I want to parse that command to get objects and data.
Could anyone please let me know whether this is possible using Gurux Library where I can pass my raw byte DLMS command to some parsing function and it gives me back parsed data.
Also is the parsing that Gurux library is doing, always expects HDLC Frame only ?
As the data I am receiving in my application is not containing HDLC start/end packets, so will I be able to parse it using the library.
Thanks & Regards,
Diptesh Patel
11 years 6 months ago
Can you post your raw data here so I can verify it and answer for your question?
diptesh
In reply to Need to parse DLMS data (raw byte array) by Kurumi
Dear Mikko,
Please find the raw data below. I have added comments to identify the sequence.
unsigned char ecs70[]={
0xd9, // Tag for Access Request
0x20, // APDU config
0x00,0x00,0x00, // Invoke ID
0x00, // Length = 0 (There is no value so length field is zero )
0x05, // Number of Entries
0x02, // Set Request
0x00,0x08,0x00,0x00,0x01,0x00,0x00,0xff, // 00,08 Clock Object, 00,00,01,00,00,ff OBIS Code
0x09, // attribute identifier (Clock base)
0x03, // Action Request
0x05, // attribute identifier (Preset_Adjust_Time)
0x04, // attribute (Adjust_to_preset_time)
0x01, // Get Request
0x02, // attribute
0x04, // attribute (Adjust_to_preset_time) // After this all bytes are for Value
0x05,0x16,0x05,0x02,0x02,0x03,0x09,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x1F,0x40,0x09,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x09,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0x00,0x09,0x0c,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x16,0x00};
Waiting for your reply.
Thanks & Regards,
Diptesh Patel
Your data seems interesting.
Can you send whole DLMS frame so we can check it.
Please, do not comment it.
What meter you are using (manufacturer and model)?
Muhammad Awais
5 years 10 months ago
I need to parse the below
I need to parse the below data
OBIS CODE: .\OBIS\test\99.98.12.xml
3:51:54 PM CB_S: 7EA01A028905FE6846E6E600C001C30007010063620CFF02003D097E
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
<GetResponse>
<GetResponsewithDataBlock>
<InvokeIdAndPriority Value="C3" />
<Result>
<LastBlock Value="00" />
<BlockNumber Value="00000001" />
<Result>
<RawData Value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
</Result>
</Result>
</GetResponsewithDataBlock>
</GetResponse>
Dear Muhammad,
Dear Muhammad,
I'll answer your question when you have created a new topic.
