  3. Capture Objects In Ansi C
Capture objects in ansi c
By KostaG , 15 March, 2023
How can I implement and replicate in ANSI C, in the client side of the program, the action of Capture Objects of profile generics.
This is the dialog GXDLMSDirector shows when I press the Capture action:
12:50:08 Method object 1.0.99.1.0.255, interface ProfileGeneric
TX: 7E A0 1B 03 23 76 89 D6 E6 E6 00 C3 01 C1 00 07 01 00 63 01 00 FF 02 01 0F 00 73 A3 7E
12:50:08
RX: 7E A0 11 23 03 96 21 CD E6 E7 00 C7 01 C1 00 00 FC B4 7E
I want to implement in C this action, in the client side, but I don´t know how to do it.
Thanks.
3 years 4 months ago
Hi, This will do what you…
This will do what you want to do:
* Calls capture of the profile generic object..
int CaptureProfileGeneric(connection* connection)
int ret;
gxProfileGeneric pg;
unsigned char ln[] = { 1,0,99,1,0,255 };
INIT_OBJECT(pg, DLMS_OBJECT_TYPE_PROFILE_GENERIC, ln);
//Invokes capture action.
dlmsVARIANT param;
GX_INT8(param) = 0;
ret = com_method(connection, BASE(pg), 2, &param);
return ret;
KostaG
Thanks a lot. It seems it…
Thanks a lot.
It seems it works well now.
  • Sravan Kumar Sunki
  • lYeWnkCDdXWOSGsl
  • Nandha
  • li5201314
  • brainstormkale…
