I'm trying to use the GuruX simulator to simulate a meter with AuthenticationEncryption and HighGMac security. When specifying the `-w` wrapper parameter on the simulator I am getting `Connection permanently rejected` when I try to connect to the meter. Without using this parameter I can connect to the meter. With the meter simulated in wrapper mode, I can connect to client 16 (public client) of the meter but I can't connect using client 1 access. So it appears that there is an auth issue.
