  3. Read Meter With Tcp(client/server)
Read meter with tcp(client/server)
By dlmsDeveloper , 1 March, 2023
hi,
I want switch between tcp client and tcp server on smart meter, by default meter work as tcp client and support server, how can I change the tcp type? which Object?
3 years 3 months ago
Hi, You need to check if…
You need to check if your meter supports auto-connect.
Using auto-connect you can ask the meter to establish the connection for the given TCP/IP address.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSAutoConnect
