  3. Simulator
Simulator
By kevin jose minj , 17 February, 2023
I started my dot net simulator using this command
Gurux.DLMS.Simulator.Net.exe -p 1000 -x simulator_template.xml -N 10
this is what I am getting in my terminal
DLMS HDLC Logical Name simulator start in ports 1000-1009.
Waiting 00:29:38 before next execution.
Server address: 1
Associations:
Client address: 16 Without authentication.
Conformance:
Get
MaxReceivePduSize: 512 MaxSendPduSize: 512
Client address: 32 Low authentication, password
Conformance:
BlockTransferWithGetOrRead, Get, SelectiveAccess
Security suite: Suite0
Security policy: Encrypted
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Broadcast block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Client address: 48 High authentication, password
Conformance:
GeneralBlockTransfer, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, DataNotification, Get, Set, SelectiveAccess, Action
Security policy: AuthenticatedEncrypted
Client address: 64 Without authentication.
Conformance:
GeneralProtection, GeneralBlockTransfer, BlockTransferWithGetOrRead, DataNotification, Get
Client address: 80 High authentication, password
Conformance:
Get, Set, Action
If I try to connect with GXDLMSDirector with localhost and port number 1000 it says Access Error: Device reports Read-Write denied . Actually what is issue here is I done anything wrong?
3 years 9 months ago
Hi, Check that your client…
Check that your client address and authentication level are correct.
Try first with those:
Physical server address: 1
Client address: 0x10
Authentication level: None
kevin jose minj
In reply to Hi, Check that your client… by Kurumi
I checked this one its…
I checked this one its working fine only why it is not working with
Client address: 48
Physical address 1
Authentication level: US
Any update on this?
