  3. Bug In Read List With Empty Array
bug in read list with empty array
By ali_bahal, 15 February, 2023
hi, when reading Ip4Setup with list , attribute 4 and 5 are arrays and when there value is null the packets does not parse correctly In ReadList method.
Tx:
00 01 00 01 00 01 00 40 C0 03 C1 06 00 2A 00 00 19 01 00 FF 02 00 00 2A 00 00 19 01 00 FF 03 00 00 2A 00 00 19 01 00 FF 04 00 00 2A 00 00 19 01 00 FF 05 00 00 2A 00 00 19 01 00 FF 06 00 00 2A 00 00 19 01 00 FF 07 00
Rx:
00 01 00 01 00 01 00 25 C4 03 C1 06 00 09 06 00 00 19 03 00 FF 00 06 55 0F 30 F9 00 01 00 00 01 00 00 06 FF FF FF FF 00 06 00 00 00 00
the response contains two array with "01 00" but in parsing it return only one null value.
ali_bahal
2 years 12 months ago
note that the list contains…
note that the list contains 6 value but parsed list only contains 5 value.
I think it's the same as this :
https://gurux.fi/node/19910
but in this case there is two null value in row.
ali_bahal
2 years 11 months ago
Hi ،should I wait more time…
Hi ،should I wait more time or you don't answer questions any more?
Hi, I believe that this is…
I believe that this is solved. Testing is on progress.
From the picture it looks like you are using C#. Is that correct?
ali_bahal
In reply to Hi, I believe that this is… by Kurumi
Hi, Yes we are using c#…
Yes we are using c# version.
Thank you in advance.
Hi, The new version will be…
The new version will be released on Monday where this is fixed.
ali_bahal
Thank you. I'll check new…
Thank you. I'll check new version after release and let you know
H, This is fixed for the…
H,
This is fixed for the version 9.0.2303.2001.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
  • mokujiny
  • Nazar
  • niels_joulz
  • Nitish_kumar
  • wilsont
