  3. [GuruxDLMS.c][Invalid Frame 10. Expected 30.]
[GuruxDLMS.c][Invalid frame 10. Expected 30.]
By jozsad , 9 February, 2023
I am trying to communicate with SL7000 meter using GuruxDLMS.c library.
I've made a cross compilation for i.MX6 processor for the library and the GuruxDLMSClientExample.
The Processor card is connecting to the meter using RS232, when I tried to connect I got an error message : Invalid frame 10. Expected 30.
I attached to log for the communication.
Can you help me to solved this problem ?
Thank you for the information and your feedback,
Best regards,
Dávid
3 years 5 months ago
Hi, Can you share this as a…
Can you share this as a text? Picture is so hard to read.
jozsad
In reply to Hi, Can you share this as a… by Kurumi
The .log file format is not…
The .log file format is not a valid extension for upload form, so I put it to comment.
Log:
# ./gurux.dlms.client.bin -S /dev/ttymxc2 -t Verbose -i HDLC -c 1
InitializeConnection
TX: 7E A0 07 03 03 93 8C 11 7E
RX: 7E A0 07 03 03 93 8C 11 7E
TX: 7E A0 2B 03 03 10 78 BF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 2B 03 03 10 78 BF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7EInvalid frame 10. Expected 30.
AARQRequest failed Data receive failed.
TX: 7E A0 07 03 03 53 80 D7 7E
RX: 7E A0 07 03 03 53 80 D7 7E
./gurux.dlms.client.bin -S /dev/ttymxc2 -t Verbose -i HDLC -c 1 -a Low -P ABCDEFGH
TX: 7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7E
RX: 7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7EInvalid frame 10. Expected 30.
In reply to The .log file format is not… by jozsad
Hi, You are only receiving…
You are only receiving the echo from the RS-232 converter. If you remove the device you get the same reply. The meter doesn't reply for some reason.
Your server address might also be different than the meter expects. Try this:
-S /dev/ttymxc2 -t Verbose -i HDLC -s 145
Check your cables if you still don't can't connect to the meter.
jozsad
In reply to Hi, You are only receiving… by Kurumi
Hi, The echo problem is…
The echo problem is solved, there was an RS485 cable instead of RS232.
Unfortunately after I request the meter there is no reply data.
Best regards,
Dávid
  • Peraturaidetetug
  • NnmIomcqcTDVWiDuCD
  • iRnseovnShdVWR…
  • HgGuaAJJjTLjzz…
  • HYpmSpMsbgNghuph
