  3. Push Listener Python
By kevin jose minj , 18 January, 2023
How to check the notifications from meter receiving or not using push listener example.I executed the file but not received any data
Media state changed. MediaState.OPEN
This is only thing showing in terminal and I am using optical probe
3 years 9 months ago
Hi, The meter sends push…
The meter sends push messages periodically. Check first that the meter is sending push messages to the serial port. Some meters are configured to send push messages for example using TCP/IP.
kevin jose minj
When I connected first time…
When I connected first time it is shown Data received message in terminal but after that no messages are came?
kevin jose minj
3 years 5 months ago
Hi, I believe that you have…
I believe that you have configured auto-connect when the meter establishes a connection for the HES, but it doesn't necessary send the push message. Try to trigger a push message and you should see it.
