  3. Create a Simulator Template Without Real Meter
Create a simulator template without real meter
By arobles , 21 November, 2022
It is possible to create a template to simulate a meter without having an actual smart meter to read the data?
I have used the crystal.xml file to understand its operation, but I only get what is related to the attached image.
3 years 10 months ago
Please, don't add images. They are hard to read. You have created a simulated meter to TCP/IP port 1000.
You can connect for the meter for example with GXDLMSDirector. Just set the TCP/IP host name and address and establish the connection for the meter.
arobles
Thanks, I have another
Thanks, I have another question, is there a way to create simulated data that is stored in the meter, data related to measurement?
Values that are read from the meter are base values. You can change those values for the XML file or add your own functionality for the simulator for PreRead -method.
