  3. Saving AssociationView To File In GuruxDLMS.c
Saving AssociationView to file in GuruxDLMS.c
By Prakash , 10 August, 2022
The function com_getAssociationView is supposed to read from the file if it exists, else read from meter and save to file. But it is not saving to the file even though 58 objects were read from the meter. Upon inspecting I found that CURRENT_ASSOCIATION[0] is null. Please let me know how to save to the file.
Sample code:
int ret = com_open(&con, port);
if (ret == 0) {
//Initialize connection.
if ((ret = com_initializeOpticalHead(&con)) != 0 || (ret =
com_updateInvocationCounter(&con, invocationCounter)) != 0
com_initializeConnection(&con)) != 0 || (ret =
com_readAllObjects(&con, outputFile)) != 0) {
printf("connection failed: %d\r\n", ret);
} else {
printf("connected ...\r\n");
while (1) {
bool result;
uint16_t volt = getVoltage(&result);
printf("volt: %d\r\n", volt);
sleep(2);
Logs:
InitializeConnection
GetAssociationView
-------- Reading Object Data 0.0.0.1.0.255
Index: 2 Value: 2
-------- Reading Object Data 0.0.0.1.1.255
Index: 2 Value: 2
-------- Reading Object Data 0.0.42.0.0.255
Index: 2 Value: 4C 4E 54 42 32 58 58 58 58 58 58 58 43 35
-------- Reading Object Data 0.0.94.91.0.255
Index: 2 Value: 0
-------- Reading Object Data 0.0.94.91.9.255
Index: 2 Value: 5
-------- Reading Object Data 0.0.94.91.11.255
Index: 2 Value: 43 33
-------- Reading Object Data 0.0.94.91.12.255
Index: 2 Value: 35 2D 33 30 41 20 20 20
-------- Reading Object Data 0.0.96.1.0.255
Index: 2 Value: 20 20 20 20 20 20 20 20 41 32 35 33 33 39 39 37
-------- Reading Object Data 0.0.96.1.1.255
Index: 2 Value: 53 63 68 6E 65 69 64 65 72 20 45 6C 65 63 74 72 69 63 20 49 6E 64 69 61 20 50 72 69 76 61 74 65 20 4C 69 6D 69 74 65 64
-------- Reading Object Data 0.0.96.1.4.255
Index: 2 Value: 2022
-------- Reading Object Data 0.0.96.2.0.255
Index: 2 Value: 0
-------- Reading Object Data 0.0.96.11.1.255
Index: 2 Value: 0
-------- Reading Object Data 0.0.96.11.4.255
Index: 2 Value: 0
-------- Reading Object Data 0.0.96.11.2.255
Index: 2 Value: 102
-------- Reading Object Data 0.0.96.11.3.255
Index: 2 Value: 0
-------- Reading Object Data 0.0.96.11.5.255
Index: 2 Value: 0
-------- Reading Object Data 1.0.0.2.0.255
Index: 2 Value: 54 44 30 30 2E 30 31
-------- Reading Object Data 1.0.0.8.0.255
Index: 2 Value: 1800
-------- Reading Object Data 1.0.0.8.4.255
-------- Reading Object Data 1.0.0.8.5.255
Index: 2 Value: 86400
-------- Reading Object Data 0.128.140.128.128.255
Index: 2 Value: 0
-------- Reading Object Data 0.128.150.128.128.255
Index: 2 Value: 53 52 30 34 2E 30 34
-------- Reading Object Data 0.128.169.128.128.255
Index: 2 Value: 6
-------- Reading Object Register 0.0.0.1.2.255
Index: 3 Value: Scaler: 1 Unit: NoUnit
Index: 2 Value: 07 E6 08 01 FF 00 00 FF FF 01 4A 00
-------- Reading Object Register 0.0.94.91.14.255
Index: 3 Value: Scaler: 1 Unit: Minute
Index: 2 Value: 20880
-------- Reading Object Register 1.0.1.7.0.255
Index: 3 Value: Scaler: 10 Unit: Active power
Index: 2 Value: 0
-------- Reading Object Register 1.0.1.8.0.255
Index: 3 Value: Scaler: 100 Unit: Active energy
Index: 2 Value: 27
-------- Reading Object Register 1.0.9.7.0.255
Index: 3 Value: Scaler: 10 Unit: Apparent power
Index: 2 Value: 0
-------- Reading Object Register 1.0.9.8.0.255
Index: 3 Value: Scaler: 100 Unit: Apparent energy
Index: 2 Value: 30
-------- Reading Object Register 1.0.11.7.0.255
Index: 3 Value: Scaler: 0.010000 Unit: Current
Index: 2 Value: 0
-------- Reading Object Register 1.0.12.7.0.255
Index: 3 Value: Scaler: 0.010000 Unit: Voltage
Index: 2 Value: 22849
-------- Reading Object Register 1.0.13.7.0.255
Index: 3 Value: Scaler: 0.010000 Unit: NoUnit
Index: 2 Value: 0
-------- Reading Object Register 1.0.14.7.0.255
Index: 3 Value: Scaler: 0.010000 Unit: Frequency
Index: 2 Value: 5000
-------- Reading Object Register 1.0.91.7.0.255
Index: 2 Value: 0
-------- Reading Object ExtendedRegister 1.0.1.6.0.255
Prakash
Prakash
3 years 11 months ago
There is some problem with
There is some problem with com_readAllObjects() call while reading extended registers. So I am not using com_readAllObjects(). It means you can't use oa_findByLN(). I directly use com_read(). For example:
unsigned char ln[] = { 1,0,32,7,0,255 };
gxRegister regObj;
INIT_OBJECT(regObj, DLMS_OBJECT_TYPE_REGISTER, ln);
int ret = com_read(&con, &regObj->base, 2);
if (ret == DLMS_ERROR_CODE_OK) {
} else {
  • JosephNok
  • IUJbutxeSTSNcNRN
  • Peraturaidetetug
  • NnmIomcqcTDVWiDuCD
  • iRnseovnShdVWR…
