  3. Arduino Client Sample Program With RS485
Arduino client sample program with RS485
By rogertaykc , 18 July, 2022
I successfully using Gurux DLMS Director to connect and upload from the meter via a USB to RS485 convertor. Next is to try with Arduino client, will the sample program Arduino client work with RS485? I understand it is designed to use RS232. Any code modification needed? Thanks!
4 years 4 months ago
The only difference between RS-485 and RS-232 is power level. The only software modifications that you need to do is change the baud rate and other serial port settings.
rogertaykc
Thanks a lot! I will give it a try very soon.
By the way, will the library & sample program handle the additional transmit enable pin for RS485? This is what i am worried about...
Best regards,
Roger Tay
Hi Roger ,
Hi Roger ,
The example is using the default Arduino serial port library and you can simply change it for others if you have problems with it.
rogertaykc
Thanks! I will give it a try first, will consult you further in future if i face any difficulty.
Best regards,
Roger Tay
Amal mp
3 years 11 months ago
In reply to Hi Mikko, by rogertaykc
Hi rogertaykc
Hi rogertaykc
Have you successfully completed this? I am also trying to read meter data via RS485 using Esp8266.
rmunoz
2 years 9 months ago
Hi All. I have the same…
Hi All.
I have the same problem as @rogertaykc. In particular, I have connected my ESP32 arduino to a UART/TTL to RS485 converter board. This board has a pin that has to be enabled when transmitting and disable to receive. I checked the com_readAllObjects() function and its subfunctions but I cannot find the time to call the serial.write() function.
Has anyone been able to connect to a meter using a RS232 to RS485 adapter board?.
PD: The model of UART/TTL to RS485 converter board is HW-97 board.
https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/
Hi rmunoz, Please, create a…
Hi rmunoz,
Please, create a new topic if you have a new question. After a while, no one knew what was the original question.
We have made several projects where RS-232 or RS-485 using Arduino. Check your wires. It's really common that the problem is there. Then check your serial baud rate. Now it's 9600.
The best way to go is if you have two Arduino boards and you can verify that you can receive bytes to the other. Then you know that your connection is working.
