  3. Gurux.DLMS Python Decryption
Gurux.DLMS python decryption
By ravichandra99 , 14 June, 2022
Hi Mikko
Im using gurux python, Im able to get data and its encrypted and in xml format
im unable to decrypt
rawdata is in
https://pastebin.com/W2XtWtR4
and the code im using is
from gurux_dlms import GXDLMSTranslator
from gurux_dlms import GXByteBuffer
data = "data here"
t = GXDLMSTranslator()
t.comments = True
t.systemTitle = "TRI00000".encode()
t.blockCipherKey = bytearray((0x54, 0x72, 0x69, 0x5F, 0x5F, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x63))
t.authenticationKey = bytearray((0x54, 0x72, 0x69, 0x5F, 0x5F, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x63))
t.serverSystemTitle = GXByteBuffer.hexToBytes("4142434445464748")
print(t.messageToXml(data))
4 years 5 months ago
Can you give the raw data in hex so I can check this from the bytes?
ravichandra99
This is rawdata
This is rawdata
https://pastebin.com/feNYWbnm
cipherkey, kindly check with this too - 52 45 53 5F 55 6E 69 63 61 73 74 41 73 73 63 30
ravichandra99
Cipher key and Authentication key are same
pls try from gurux_dlms import GXDLMSTranslator
data = "00 01 00 01 00 10 00 58 DB 08 41 42 43 44 45 46 47 48 4D 30 00 00 00 00 11 98 4B 30 35 F0 35 51 06 72 DA 54 93 70 8E 70 9B 3D BD 31 02 14 CE 10 A9 89 81 92 53 80 42 A9 19 D7 52 62 7B E6 70 B3 13 30 E1 53 B6 9D 0B 6D 14 8D 86 F9 D4 6F 6B C3 09 24 A8 4C 50 03 82 FF 05 77 A5 9B F1 1F CD 78"
t.comments = True
t.blockCipherKey = bytearray(0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
t.authenticationKey = bytearray((0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
or 52 45 53 5F 55 6E 69 63 61 73 74 41 73 73 63 30 as cipher key and auth key
Get the latest version (1.0.126). There was an issue with GXDLMSTranslator and ciphering.
ravichandra99
Hi Mikko Ihad tried with the
Hi Mikko Ihad tried with the lastest version , still im not getting decrypted data
its working with Director GUI, but not working using python,
One more thing is earlier python client command used to work , but now its also not working
im using ipv6 to connect to meter ..
ravichandra99
t.comments = True
t.blockCipherKey = bytearray((0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
The above is code i had used
xml: https://pastebin.com/W2XtWtR4
encrypted: https://pastebin.com/feNYWbnm
Im stuck from last 2 weeks
Your block and authentication keys are wrong. Use 54 72 69 5F 5F 5F 55 6E 69 63 61 73 74 41 73 63
