  3. Problem In Read ActivityCalendar
Problem in Read ActivityCalendar
By NGR0223 , 8 April, 2022
Hi, I got when I use the clientExample in c++ to read the ActivityCalendar with attribute 5.
I use the program parameters: -S /dev/ttyUSB0:9600:8None1 -c 5 -s 1 -a Low -P XXXXXXXX -i WRAPPER -o objects.xml -g "0.0.13.0.0.255:5", and I do not modify any code.
The part of trace.txt is showed below:
TX: 22:12:49 00 01 00 05 00 01 00 0D C0 01 C1 00 14 00 00 0D 00 00 FF 05 00
00 01 00 01 00 05 00 82 C4 02 88 01 00 00 03 A8 00 78 02 16 01 02 04 12 00 40 11 00 09 06 00 00 2B 00 05 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 03 00 01 02 02 02 0F 01 16 01 02 02 0F 02 16 01 00 01 00 01 00 05 00 04 0E 01 00 03
The logFile.txt is showed below:
Error! Index: 5 read failed: Invalid Invoke ID.
Could you tell me where the mistake I make or how can I read ActivityCalendar correctly?
Nowadays, I have tested the other attribute index from 2-10 of the ActivityCalendar. All of them work correctly except the index 5.
And during my test, I found another problem that I don't understand. It is that the program does not work correctly when I set a breakpoint and debug it by step at the following statement:
// code
if ((ret = comm.Read(obj, index, value)) != DLMS_ERROR_CODE_OK)
// code finish
The purpose of step-by-step debugging is to see how the program handle the NextBlock. There are no errors until the end of the program but the program does not handle the NextBlock. For example, when I run the program without breakpoint to read the ActivityCalendar with attribute 9, there are six block in total gotten from the meter. However, when I set the breakpoint, there is only first block gotten from the meter. Both of the trace.txt are showing below:
// without breakpoint
TX: 16:22:18 00 01 00 05 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
00 01 00 01 00 05 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 30 00 07
TX: 16:22:23 00 01 00 05 00 01 00 0D C0 01 81 00 14 00 00 0D 00 00 FF 09 00
00 01 00 01 00 05 01 2C C4 02 81 00 00 00 00 01 00 82 01 20 01 08 02 02 11 00 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 08 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 11 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 01 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 15 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF
TX: 16:22:33 00 01 00 05 00 01 00 07 C0 02 82 00 00 00 01
00 01 00 01 00 05 01 29 C4 02 82 00 00 00 00 02 00 82 01 1D 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 02 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03
TX: 16:22:43 00 01 00 05 00 01 00 07 C0 02 83 00 00 00 02
00 01 00 01 00 05 01 28 C4 02 83 00 00 00 00 03 00 82 01 1C 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 03 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 04 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF
TX: 16:22:54 00 01 00 05 00 01 00 07 C0 02 84 00 00 00 03
00 01 00 01 00 05 01 29 C4 02 84 00 00 00 00 04 00 82 01 1D 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 05 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03
TX: 16:23:04 00 01 00 05 00 01 00 07 C0 02 85 00 00 00 04
00 01 00 01 00 05 01 28 C4 02 85 00 00 00 00 05 00 82 01 1C 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 06 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 07 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF
TX: 16:23:14 00 01 00 05 00 01 00 07 C0 02 86 00 00 00 05
00 01 00 01 00 05 00 9B C4 02 86 01 00 00 00 06 00 81 90 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF
TX: 16:23:24 00 01 00 05 00 01 00 05 62 03 80 01 00
00 01 00 01 00 05 00 05 63 03 80 01 00
// without breakpoint finish
// with breakpoint
TX: 16:17:59 00 01 00 05 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
TX: 16:18:07 00 01 00 05 00 01 00 0D C0 01 81 00 14 00 00 0D 00 00 FF 09 00
00 01 00 01 00 05 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 30 00 07 00 01 00 01 00 05 01 2C C4 02 81 00 00 00 00 01 00 82 01 20 01 08 02 02 11 00 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 08 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 11 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 01 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 15 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF
TX: 16:18:29 00 01 00 05 00 01 00 05 62 03 80 01 00
00 01 00 01 00 05 01 2C C4 02 81 00 00 00 00 01 00 82 01 20 01 08 02 02 11 00 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 08 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 11 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 01 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 15 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 00 01 00 01 00 05 00 05 63 03 80 01 00
// with braekpoint finish
Could you tell me what happened when I set the breakpoint and debug step by step?
Thanks in advance.
4 years 3 months ago
Your meter is sending invalid data and I believe that there is an issue with the meter. You need to verify this from the meter vendor. Data is missing from the meter reply and invoke ID is wrong.
I haven't heard from this breakpoint. What compiler you are using? I believe it's related to the compiler.
NGR0223
I am using the CLion on Linux
I am using the CLion on Linux, the compiler is g++ whose version is 8.3.0. And the cmake version 3.21.1, make version 4.2.1, gdb version 10.2.
I'll try the same code and process on other Linux PC and Windows PC.
Thanks for your reply.
We'll try this with CLion, but it takes some time because our clients are keeping us busy at the moment. There should be no reason why your breakpoint lost frames.
NGR0223
I try the ActivityCalendar with index 5 on another meter and the ClientExample works correctly. However, there is still the problem of breakpoint.
Through observation, I think I found the wrong location. When the program run to function(int CGXCommunication::ReadData(CGXByteBuffer &reply, std::string &str) of communication.cpp about in the line 1030, the problem happened on the code: if (ret = Read(0x7E, reply) != 0).
Because the after str are different between breakpoint and without breakpoint. In Debug mode, the first part of the str is the AARE frame, however, in the normal mode, the str is the correct response from the meter.
The output of two mode are showed below:
// breakpoint
InitializeConnection
Read failed. Timeout occurred.
Read failed.
00 01 00 01 00 05 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 30 00 07Data send failed. Try to resend 1/3
Read failed.
00 01 00 01 00 05 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 30 00 07 00 01 00 01 00 05 01 2C C4 02 81 00 00 00 00 01 00 82 01 20 01 08 02 02 11 00 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 08 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 11 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 01 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 15 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FFData send failed. Try to resend 1/3
Index: 5 Value: []
Read failed.
00 01 00 01 00 05 00 04 0E 01 00 03 00 01 00 01 00 05 00 05 63 03 80 01 00Data send failed. Try to resend 1/3
// breakpoint finish
Read failed.
Read failed.
Read failed.
00 01 00 01 00 05 01 2C C4 02 81 00 00 00 00 01 00 82 01 20 01 08 02 02 11 00 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 08 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 0C 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 11 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 01 01 0A 02 03 09 04 00 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 15 00 00 FF 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FFData send failed. Try to resend 2/3
Read failed.
Read failed.
00 01 00 01 00 05 01 29 C4 02 82 00 00 00 00 02 00 82 01 1D 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 02 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03Data send failed. Try to resend 2/3
Read failed.
Read failed.
00 01 00 01 00 05 01 28 C4 02 83 00 00 00 00 03 00 82 01 1C 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 03 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 04 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FFData send failed. Try to resend 2/3
Read failed.
Read failed.
00 01 00 01 00 05 01 29 C4 02 84 00 00 00 00 04 00 82 01 1D 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 05 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03Data send failed. Try to resend 2/3
Read failed.
Read failed.
00 01 00 01 00 05 01 28 C4 02 85 00 00 00 00 05 00 82 01 1C 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 06 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 02 11 07 01 0A 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FFData send failed. Try to resend 2/3
Read failed.
Read failed.
00 01 00 01 00 05 00 9B C4 02 86 01 00 00 00 06 00 81 90 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FF 02 03 09 04 FF FF FF FF 09 06 FF FF FF FF FF FF 12 FF FFData send failed. Try to resend 2/3
Index: 5 Value: [0 00:00:00 0.0.10.0.100.255 08:00:00 0.0.10.0.100.255 12:00:00 0.0.10.0.100.255 17:00:00 0.0.10.0.100.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 1 00:00:00 0.0.10.0.100.255 09:00:00 0.0.10.0.100.255 21:00:00 0.0.10.0.100.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 2 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 3 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 4 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 5 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 6 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255, 7 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255 255.255.255.255.255.255]
Read failed.
Read failed.
00 01 00 01 00 05 00 05 63 03 80 01 00Data send failed. Try to resend 2/3
  • RicardoNoula
  • ScottKit
  • liha_2019
  • FiqJXzPfbTtORWoZ
