  3. Pushlistener
Pushlistener
By Sima27 , 27 March, 2022
When i want to compile Pushlistener i get the following error messages. What am i doing wrong?
D:\daten\dlms\Arduino_IDE\pushListener\src\gxserializer.c: In function 'ResetPosition':
D:\daten\dlms\Arduino_IDE\pushListener\src\gxserializer.c:4280:22: error: 'gxSerializerSettings' has no member named 'currentObject'
4280 | serializeSettings->currentObject = NULL;
D:\daten\dlms\Arduino_IDE\pushListener\src\gxserializer.c:4281:22: error: 'gxSerializerSettings' has no member named 'currentIndex'
4281 | serializeSettings->currentIndex = 0;
exit status 1
Fehler beim Kompilieren für das Board NodeMCU 1.0 (ESP-12E Module).
4 years 2 months ago
DLMS_IGNORE_MALLOC was defined in ArduinoIgnore.h.
This is now fixed. get the latest version from GitHub.
Sima27
Dank You very much!
Dank You very much!
Have a nice day
Sima27
I am sorry, but the error is
I am sorry, but the error is still there:
D:\daten\Arduino\gurux3\Arduino_IDE\pushListener-2\src\gxserializer.c: In function 'ResetPosition':
D:\daten\Arduino\gurux3\Arduino_IDE\pushListener-2\src\gxserializer.c:4280:22: error: 'gxSerializerSettings' has no member named 'currentObject'
D:\daten\Arduino\gurux3\Arduino_IDE\pushListener-2\src\gxserializer.c:4281:22: error: 'gxSerializerSettings' has no member named 'currentIndex'
exit status 1
Thank You for more information
Did you get the latest version from GitHub and copy source and include folders under the development folder?
Sima27
Yes I did it again. I copied
Yes I did it again. I copied \include, \src, \vs, makefile form gurux4\development in the pushlistener directory and opened pushlistener.ino with arduino IDE.
Result:
D:\gurux4\Arduino_IDE\pushListener\src\gxserializer.c: In function 'ResetPosition':
D:\gurux4\Arduino_IDE\pushListener\src\gxserializer.c:4280:22: error: 'gxSerializerSettings' has no member named 'currentObject'
D:\gurux4\Arduino_IDE\pushListener\src\gxserializer.c:4281:22: error: 'gxSerializerSettings' has no member named 'currentIndex'
exit status 1
Thank You for Your help
