I'm using a DLMS Siemens meter and I'm trying to read the Association View but I'm getting an Invalid OBIS Code error after a few minutes runnig the Client example in c#.
This error also happens when I use the GXDLMSDirector. What could be causing this error?
There seems to have an issue with the meter. The meter returns an invalid logical name for the Tcp Udp Setup object. Ask if there is a firmware update available from your meter vendor.
