  3. AARQRequest Failed Rejected Permament and No Reason Given
AARQRequest failed Rejected permament and No reason Given
By bcits , 5 February, 2022
Dear Gurux,
I am getting "AARQRequest failed Rejected permament and No reason Given" Error while establishing a connection between Meter. I try the same Authentication key, password etc in gurux director its working fine but in Gurux ANSCI C Client code getting this error. I have shared the trace log for your reference, Please help me out.
updateInvocationCounter
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 E6 06 02 02 E6 07 04 00 00 00 01 08 04 00 00 00 01 BE F7 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 BC 00 07 FD C5 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 00 00 00 12 E8 EC 7E
Invocation counter: 19 (0x13)
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 20 61 03 73 05 9E 81 80 14 05 02 02 E6 06 02 02 E6 07 04 00 00 00 01 08 04 00 00 00 01 BE F7 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 31 31 31 31 31 31 31 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 00 13 70 68 44 53 2E 0B F2 B7 2B 7E AA F6 BB 5F 21 BC 75 AF 1E 6A 87 DE 34 F6 F7 6F 31 E4 7E
RX: 7E A0 6D 61 03 30 A2 73 E6 E7 00 61 5F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 0E A4 0A 04 08 56 54 4B 30 30 31 31 38 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 56 69 73 6F 6E 69 6E 73 74 72 75 6D 65 6E 74 73 BE 19 04 17 28 15 30 00 00 00 00 D2 87 76 0C 7B 1C BF 38 0C A4 75 CC B0 2A FC E5 D4 FE 7E
AARQRequest failed Rejected permament.
TX: 7E A0 07 03 61 53 65 81 7E
Rejected permanent.
Thanks and Regards,
Tapan Kumar Das
4 years 5 months ago
I don't have the block cipher or authentication keys, so I can't check what is causing this. Can you create a ticket and add block cipher or authentication keys so I can check this. Read the meter with GXDLMSDirector and add hex trace so I can compare what settings are different.
bcits
Dear Mikko,
Dear Mikko,
Thanks For your response,
I can connect through Gurux Director, But through GuruxClientexample.c I am getting this error below I have attached the logs for both Gurux director and GuruxCilentExample.c.
Block Cipher Key: 0123456789ABCDEF (ASCII)
Authentication Key: 0123456789ABCDEF(ASCII)
Dedicated Key: 0123456789ABCDEF(ASCII)
Invocation Counter is not required.
GuruxDirector Trace:
13:43:26 Send SNRM request.
TX: 7E A0 07 03 41 93 5A 64 7E
13:43:26
RX: 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 02 E6 06 02 02 E6 07 04 00 00 00 01 08 04 00 00 00 01 BE F7 7E
13:43:26 Send AARQ request.
TX: 7E A0 65 03 41 10 5B 72 E6 E6 00 60 57 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 31 31 31 31 31 31 31 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 56 69 73 6F 6E BE 28 04 26 21 24 20 00 00 00 00 D5 91 35 E9 51 C0 0C C6 AE 4D CF 8D 44 A3 4F 5E CD FA 3F 63 CA C4 86 13 16 D1 8D B1 C8 C7 8E 70 9D 7E
13:43:26
RX: 7E A0 56 41 03 30 7E FC E6 E7 00 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 56 54 4B 30 30 31 31 38 BE 23 04 21 28 1F 30 00 00 00 00 D4 86 76 53 29 65 4C 9E BF 64 9F 75 01 2E 43 89 E1 D3 AA 34 8E 96 FC A5 D3 47 45 0A 7E
13:43:36 Send Keep Alive
TX: 7E A0 20 03 41 32 AB 08 E6 E6 00 D0 12 20 00 00 00 01 E3 67 B2 94 4F CD 52 27 04 31 EC 0E 85 9E 76 7E
13:43:36
RX: 7E A0 21 41 03 52 0E B1 E6 E7 00 D4 82 00 11 20 00 00 00 01 C9 05 81 08 DA 71 A5 18 F8 26 3D 53 77 E7 7E
GuruxClientExample.c Trace:
TX: 7E A0 54 03 41 10 12 22 E6 E6 00 60 46 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 31 31 31 31 31 31 31 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 56 69 73 6F 6E BE 17 04 15 21 13 20 00 00 00 00 D5 90 25 D9 66 AD 20 F6 9B 7B E6 A8 82 1D 07 99 7E
RX: 7E A0 4C 41 03 30 71 E3 E6 E7 00 61 3E A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 56 54 4B 30 30 31 31 38 BE 19 04 17 28 15 30 00 00 00 00 D2 87 76 0C 7B 1C BF 38 0C A4 75 CC B0 2A FC E5 8A 42 7E
AARQRequest failed No reason given.
TX: 7E A0 07 03 41 53 56 A2 7E
No reason given.
Please do the need full.
I answered for your ticket.
  • UIRlLOZQoyTZHC…
  • mpjTCKVBgHdfcCSDJDRc
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
