  3. Gxtime Y38K Bug
gxtime Y38K bug
By wildstray , 10 January, 2022
I'm working on clock registers and noticed that gxtime structure using everywhere to represent timestamps in other structures or alone, has the value only 32 bit long in epoch format...
typedef struct
#ifdef DLMS_USE_EPOCH_TIME
uint32_t value;
#else
struct tm value;
#endif
int16_t deviation;
DATETIME_SKIPS skip : 16;
DLMS_DATE_TIME_EXTRA_INFO extraInfo : 8;
DLMS_CLOCK_STATUS status : 8;
} gxtime;
So the library itself is affected by Y38K bug. Are also raw COSEM timestamps in 32 bits format... so this is a structural and uncorrectable bug... or it could be avoided changing uint32_t with uint64_t value in struct gxtime?
TIA!
Andrea
