  3. Connect Simulator Via TCP/IP
Connect Simulator via TCP/IP
By Samir Samanta , 10 January, 2022
Gurux.Serial
I have installed Gurux directory in my VMware inside the mac machine. I have create a device from the Gurux directory and connected by the terminal. Now I want to connect that Simulator from my Xcode project in mac machine. But I am not able to connect that I got some error like :
Error
stream event NSStreamEvent(rawValue: 8)
The operation couldn’t be completed. Connection refused
So is this possible to connect the VMware simulator from the mac machine. Please help regarding this.
4 years 6 months ago
If you have started the simulator you should be able to connect to it. Check your TCP/IP port. This error means that TCP/IP connection fails. The reason usually is an invalid IP address or port number.
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
