  3. Gurux Convert To XML
Gurux Convert to XML
By Siva_Sentz , 24 November, 2021
Hi Team,
We have a project, which customers will send the data in DLMS protocol. With the help of the Gurux library, we were able to make a connection between client and server.
Here the customer is sending the String and Integer data types. While converting this into XML, we are getting any tags in it. Do we need to set/enable any flag for it?
4 years 9 months ago
You only need to set authentication and block cipher keys if ciphering is used.
If you add one frame here so I can check what is the problem.
Siva_Sentz
Can you check with this
Can you check.
Data is ciphered and if I don't have authentication and block cipher keys I can't decrypt them.
Siva_Sentz
Hi ,
This data is decrypted
I'm sorry to say, but this data is encrypted and not decrypted.
[Message removed]
Check your authentication key if you are receiving an invalid authentication tag error.
Miko
