  3. Errors In Compiling Arduino Server For ESP32
Errors in compiling Arduino server for ESP32
By bhatiasidharth.89 , 14 August, 2021
I am trying to compile the Arduino server example for ESP32 but I am getting some errors. The code compiles and works fine for Arduino Mega. Following are the errors:
Arduino: 1.8.15 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
server:990:5: error: expected constructor, destructor, or type conversion before '(' token
ISR(TIMER1_COMPA_vect) {
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: In function 'int loadTargets(GXPushObjects*, gxTarget*, short unsigned int*)':
server:616:75: error: invalid conversion from 'short unsigned int' to 'DLMS_OBJECT_TYPE {aka tagDLMS_OBJECT_TYPE}' [-fpermissive]
if ((ret = oa_findByLN(Server.getObjects(), savedObjects->values[pos].objectType, savedObjects->values[pos].logicalName, &it)) != 0)
In file included from C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\included\dlmssettings.h:42:0,
from C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\included\serverevents.h:38,
from C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\GXDLMSServer.h:38,
from C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino:35:
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\included\objectarray.h:112:9: note: initializing argument 2 of 'int oa_findByLN(objectArray*, DLMS_OBJECT_TYPE, const unsigned char*, gxObject**)'
int oa_findByLN(
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: In function 'void setTimer()':
server:973:3: error: 'TCCR1A' was not declared in this scope
TCCR1A = 0;
server:974:3: error: 'TCCR1B' was not declared in this scope
TCCR1B = 0;
server:976:3: error: 'TCNT1' was not declared in this scope
TCNT1 = 0;
server:978:3: error: 'OCR1A' was not declared in this scope
OCR1A = 15624;// = (16*10^6) / (1*1024) - 1 (must be < 65536)
server:980:19: error: 'WGM12' was not declared in this scope
TCCR1B |= (1 << WGM12);
server:982:19: error: 'CS12' was not declared in this scope
TCCR1B |= (1 << CS12) | (1 << CS10);
server:982:33: error: 'CS10' was not declared in this scope
server:984:3: error: 'TIMSK1' was not declared in this scope
TIMSK1 |= (1 << OCIE1A);
server:984:19: error: 'OCIE1A' was not declared in this scope
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: At global scope:
server:990:4: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: In function 'void svr_postWrite(dlmsSettings*, gxValueEventCollection*)':
server:1789:67: error: invalid conversion from 'unsigned char*' to 'const char*' [-fpermissive]
GXTRACE(PSTR("Low level password: "), associationLow.secret.data);
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino:279:6: note: initializing argument 2 of 'void GXTRACE(const char*, const char*)'
void GXTRACE(const char* str, const char* data)
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: In function 'void svr_postAction(dlmsSettings*, gxValueEventCollection*)':
server:1817:69: error: invalid conversion from 'unsigned char*' to 'const char*' [-fpermissive]
GXTRACE(PSTR("High level password: "), associationHigh.secret.data);
server:1824:73: error: invalid conversion from 'unsigned char*' to 'const char*' [-fpermissive]
GXTRACE(PSTR("High level password: "), associationHighGMac.secret.data);
C:\Users\MKBHATIA\Documents\gurux_esp32_arduino\server\server.ino: In function 'DLMS_SOURCE_DIAGNOSTIC svr_validateAuthentication(dlmsServerSettings*, DLMS_AUTHENTICATION, gxByteBuffer*)':
server:1942:58: error: invalid conversion from 'unsigned char*' to 'const char*' [-fpermissive]
GXTRACE(PSTR("Valid low level password."), password->data);
exit status 1
There were a few more errors but I could correct them by making the following changes to the server.ino file:
1. Changed EEPROM.update to EEPROM.write
2. Added a define for LED_BUILTIN
I am using the latest code from Github and latest Arduino IDE 1.18.15
Regards
Sidharth Bhatia
5 years 1 month ago
Hi Sidharth,
Hi Sidharth,
What is your additional Board Manager Url? You can find that from the Arduino settings.
bhatiasidharth.89
5 years 1 month ago
The additional Board Manager Url is:
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/pack…
5 years 1 month ago
Get the latest version from GitHub. Compiler errors for this board are fixed. Let me know if you have any problems.
bhatiasidharth.89
5 years 1 month ago
Thanks for solving the compile errors. I tried with the latest version from GitHub and the code does compile fine. But the DLMS Director is not able to connect to the meter. The debug port shows the following log when the ESP32 starts:
:Communication speed 300..:Test mode Is OFF...:LLS password..:HLS password.
Regards
5 years 1 month ago
I believe that invalid data is read from the flash. Find load() method and return zero. It will create all objects and use the default values. Something like this:
uint16_t load()
return 0;
bhatiasidharth.89
5 years 1 month ago
Thanks, that worked. The DLMS director is able to connect to the meter now. But I don't get any logs on the second serial port which I get on the Arduino Mega apart from the log at the start of the sketch. Is it something to do with the change you have suggested above and would I need to keep this change permanently for ESP32? Also, the log at the startup shows EEPROM size to be 0.
Regards
Sidharth
5 years 1 month ago
Hi Sidharth,
Hi Sidharth,
If EEPROM size is zero then it might be the reason for this. I believe that your app can't access the EEPROM for some reason or there is no EEPROM.
You should receive trace if testMode is set. Check your cables. Can you share information from your board? I'll order one so this can be tested with the same HW.
bhatiasidharth.89
5 years 1 month ago
I am using the ESP32_Devkitc_V4 board. I did some research and found out that for ESP32, by default the EEPROM.length() function returns 0. We would need to use the following command to initialise the EEPROM first: EEPROM.begin(EEPROM_SIZE). Here the EEPROM_SIZE is a variable (or a macro definition) specifying the number of bytes we need for the EEPROM storage. I believe the maximum would be 512 bytes.
The EEPROM.length() function will still return zero but the EEPROM would be accessible. Instead we can get the EEPROM length by reading the value of EEPROM_SIZE variable.
Could you please tell me how much space would be needed in the EEPROM for the server Arduino sketch?
Regards
bhatiasidharth.89
5 years 1 month ago
Another option is given here:
Another option is given here: https://esp32.com/viewtopic.php?t=7012
But it seems this would require large number of changes to keep the compatibility with the AVR boards.
5 years 1 month ago
SIze of the EEPROM depends on what you want to save. For example, what are the sizes of the profile generic buffers.
