  3. Sometime Get Error 269 On Arduino When Communicating With DLMS Meter
Sometime get Error 269 On Arduino when communicating with DLMS Meter
By mightyChamp , 24 July, 2021
Sometime when communicating with meter I get 269 Checksum Error, and thereafter data didn't parsed in Arduino.
Please help me how can I resolve this Issue.
Thank You
Here is my log:
Serial Write:7EA0190341D4023FE6E600C00181000701005E5B04FF020078FD7E
frame Data:7EA06E41037C3CDDE6E700C40181000101020F02020FFE162102020FFE162102020FFE162102020FFE162302020FFE162302020FFE162302020F01161E02020F012002020F01162002020F01161F02020F01161E02020F01161F02020FFE16FF02020FFE16FF02020FFE16FF97997E
Received bytes:
111
Data send failed. Try to resend. 1
1frame Data:7EA06E41037C3CDDE6E700C40181000101020F02020FFE162102020FFE162102020FFE162102020FFE162302020FFE162302020FFE162302020F01161E02020F012002020F01162002020F01161F02020F01161E02020F01161F02020FFE16FF02020FFE16FF02020FFE16FF97997E
1frame Data:7EA06E41037C3CDDE6E700C40181000101020F02020FFE162102020FFE162102020FFE162102020FFE162302020FFE162302020FFE162302020F01161E02020F012002020F01162002020F01161F02020F01161E02020F01161F02020FFE16FF02020FFE16FF02020FFE16FF97997E7EA0074103715E667E
break due to 269
com_read failed. 269
Serial Write:7EA0190341F6123DE6E600C00181000701005E5B04FF0400A8A97E
1frame Data:7EA01541039E7083E6E700C401810006000000007BDF7E
mightyChamp
5 years 1 month ago
We found that our MCU missed
We found that our MCU missed a byte from received data, So is there any method to recover from it. without calling profile generic obis again.
5 years 1 month ago
The client application will re-send the command if the meter doesn't reply. If your app can check that the data is corrupted and rejects the message there should be no problems after the message re-sent.
mightyChamp
5 years 1 month ago
In Arduino code, If a byte is missed from uart, then it gives error of 269 and then it didn't resend same command. And I tried to send again by some modification in code, but it didn't work, as shown in log.
On 2nd try it gives a small frame which is appended to previous data as shown in log.
Received bytes:
111
5 years 1 month ago
You are right. Re-send is not implemented for Arduino. You need to re-send data with this:
if ((ret = Serial.write(data->data, data->size)) != data->size)
I added re-send to the worklist and it will be implemented next week.
mightyChamp
5 years 1 month ago
Serial transmit is implemented in Arduino as shown:
if ((ret = com_readSerialPort(0x7E)) != 0 )
if (ret == DLMS_ERROR_CODE_RECEIVE_FAILED && resend == RESEND_COUNT)
return DLMS_ERROR_CODE_SEND_FAILED;
++resend;
GXTRACE_INT(PSTR("Data send failed. Try to resend."), resend);
//If failed to write all bytes.
GXTRACE(PSTR("Failed to write all data to the serial port.\n"), NULL);
In my case, Serial data is transmitted twice, but I get two different response from meter.
First I send :
Response:
2nd time send:
Response:
7EA0074103715E667E
So sending again is not working in my case, If I get same response then there is no issue. but I am getting different responses. So I have to call obis again.
5 years 1 month ago
Meter's reply is invalid and when you try to read it again the meter can handle it and returns keep alive. I believe that the only way to handle this is to close the connection and read data again.
mightyChamp
5 years 1 month ago
if com_read(pg, 2); fails then I recall com_read(pg, 2) without com_close(), it start from previous fail and I got all data from it.
Is it ok to call com_read() again.
Thank You
5 years 1 month ago
In reply to Hello, by mightyChamp
It's great if this will work, but note that this will work only when reply data is coming in one frame. It will not work if you try to read the profile generic buffer.
mightyChamp
5 years 1 month ago
Thanks for info, I done it in profile generic only, didn't try in Data or register.
It is working, When get 269 error, my code call com_read(0 with same attribute again, and its working since 2 days.
But as you mentioned It will not work. So have to found another solution, as reading blling perioid tooks about 5-6 second of time. So, calling whole profile generic again, is not a proper solution for us.
if a profile generic frame missed a byte, then by resending frame again, meter will send keep live, but if I send it again , Can meter will send actual data again?
Thank You
5 years 1 month ago
That depends on how it's implemented for the meter. Meters are working differently with this.
