  3. Meter Readings In KWH,KVAH,KVARH, KW,KVA
Meter Readings in KWH,KVAH,KVARH, KW,KVA
By Bhaumik , 13 July, 2021
I am using Indian standard IS15959-2 meter for testing.
Currently, We are getting values from meter in Wh,VAh,VArh in IP, LS , billing and push data. Is it possible to convert those values in KWH,KVAH,KVARH, KW,KVA format respectively?
Also need to update Obis code display name as per the value conversion.
Regards
Bhaumik
5 years 4 months ago
Hi Bhaumik,
Hi Bhaumik,
GXDLMSDirector reads values from the meter and it doesn't change the value to another format. It's not possible to convert Wh to KWh in GXDLMSDirector. You can try to change the unit for the meter if you like to.
