  3. IS 15959 Part 2 Authentication Issue
IS 15959 Part 2 authentication issue
By mightyChamp , 8 July, 2021
Previously I have IS 15959 Part1 Supported meter, I can communicate with it using low level authentication from C library. Now I received IS15959 Part 2 Supported meter, But I can't communicate with it, It gives error of 279 (Authentication Error).
Please help me that what configuration or parameter needed to communicate with IS 15959 Part 2 meter.
5 years 2 months ago
You need to change the client's address and password. Try to connect with GXDLMSDirector first. It will help you to get the correct parameters.
mightyChamp
