  3. Wrong Certificate Serial Number Received From Gurux Remove The Certificaet
Wrong certificate serial number received from gurux remove the certificaet
By aoudumbarpawar , 24 June, 2021
Hii Sir,
With the updated gurux i am not able to remove any certificate from the meter.
while testing i found that the gurux sending wrong serial number (inverse direction) of the certificate for remove certificate method.
E.g:
Actual Serial Number of the certificate
Decimal = > 1001562
Hex = > 0x0f 48 5a
03 0f 48 5a == > for export certificate => gurux certificate number received from gurux by serial number
03 5a 48 0f == > for remove certificate => remove gurux root certificate serial number received from gurux by serial number
AP
5 years 1 month ago
If you add a new certificate it should override the old one.
aoudumbarpawar
5 years 1 month ago
Hii,
Hii,
Yes override it. problem is that for same certificate Export certificate received correct serial number from gurux (MSB-LSB) but for remove certificate request received wrong certificate serial number from gurux.
AP
aoudumbarpawar
5 years 1 month ago
Hii,
Hii,
Below is the request log details for the export certificate method and remove certificate method.
------------------------------ Log of export certificate ------------------------------------------------------------------
TX:7E A0 5A 00 02 BA 69 61 54 3C 3F E6 E6 00 C3 01 C1 00 40 00 00 2B 00 01 FF 07 01 02 02 16 01 02 02 09 03 0F 48 5A 09 31 43 4E 3D 52 6F 6F
74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 C8 B1 7E
Serial Number in request:
0F 48 5A
---------------------------- Log of remove certificate -------------------------------------------
TX:7E A0 5A 00 02 BA 69 61 54 3C 3F E6 E6 00 C3 01 C1 00 40 00 00 2B 00 01 FF 08 01 02 02 16 01 02 02 09 03 5A 48 0F 09 31 43 4E 3D 52 6F 6F
74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 AA 7F 7E
5A 48 0F
AP
5 years 1 month ago
You are right. Thank you for pointing this out. I created an issue from this.
http://gurux.fi/node/18676
This is fixed for the next release.
  • Malcolmactig
  • mhliang
  • Kevinmug
  • mohanadalhweiti
  • dawnso11
