We have some meters that need to have their clocks synchronized when they are mounted. Is it possible to answer a push message with a correct timestamp? For example if the meter sends a push message when it´s mounted the first time, is it then possible to answer with a timestamp? Or do we simply have to create a new connection and pass a GXDLMSClock object to the meter?
Regards
Helena
Hi Helena,
Hi Helena,
You can't answer for the push message and client needs to create a new connection to update the clock.
