  3. Question: How To Read Objects Using LN and The Object List On a SN Meter?
Question: how to read objects using LN and the object list on a SN meter?
By Jeroen88 , 10 April, 2021
I finally succeeded in reading the Object List of a Landis Gyr E650 using the Arduino GuruxDLMS.c library. Next I was able to read the clock and registers, like 1.8.1 and 32.7.0, by explicitly setting the SN found in the object list.
I also have a question. I was able to read the registers using SN directly by setting the object’s shortName. I did:
//Read register
gxRegister register1;
cosem_init(BASE(register1), DLMS_OBJECT_TYPE_REGISTER, "1.1.1.8.1.255");
register1.base.shortName = 0x0b20;
com_read(BASE(register1), 3);
com_read(BASE(register1), 2);
obj_toString(BASE(register1), &data);
GXTRACE(PSTR("Register"), data);
Now that I am able to read the object list for this SN meter, there must be an easy way to retrieve the short name from the Object List. I retrieved the object list like this:
ret = com_getAssociationView();
if(ret != DLMS_ERROR_CODE_OK) {
GXTRACE_INT(PSTR("com_getAssociationView failed"), ret);
return ret;
GXTRACE_INT(PSTR("com_getAssociationView SUCCEEDED"), ret);
Could you help me how to read a register using it’s Logical Name by looking up it’s Short Name in the object list?
Best Jeroen
5 years 5 months ago
This is the only way to do it. You need to read the association view and then save a short name so you can use it later. There is no formula, etc to count short name from the logical name. You can think short name as a memory address and it might be different even the same meter between the firmware versions.
You can get short name from the shortName of the base object. Something like this:
gxRegister reg;
//INIT, etc...
reg.base.shortName
Jeroen88
Thanks for your reaction. My question is: is there any functions in the Gurux.c library to look up a LN in the object list to find the SN? Or do I just have to loop the object list like this:
gxObject* obj;
for (size_t pos = 0; pos != Client.GetObjects()->size; ++pos) {
ret = oa_getByIndex(Client.GetObjects(), pos, &obj);
You can find objects by logical name using oa_findByLN-method.
