  3. Using DLMS Client Example For LG E650 I Get "Use Logical Name Referencing Is Wrong. Change It!"
Using DLMS client example for LG E650 I get "Use Logical Name referencing is wrong. Change it!"
By Jeroen88 , 6 April, 2021
Hi Miko,
Using DLMS client example (cpp) for LG E650 I get "Use Logical Name referencing is wrong. Change it!", but I am shure that I choose 'false' for 'useLogicalNameReferencing'. If I set it to 'true' I get 'AARQRequest failed (273) Rejected permament'.
What am I doing wrong?
Best Jeroen
5 years 7 months ago
Hi Jeroen,
Hi Jeroen,
Try to connect with GXDLMSDirector first. Meters what we have are using SN referencing. So that should be correct. If it still fails add trace here and I can try to check the bytes.
