  3. Unable To Cast Object of Type 'System.Byte[]' To Type 'System.IConvertible'
Unable to cast object of type 'System.Byte[]' to type 'System.IConvertible'
By Dmitry1 , 23 March, 2021
Hi, i'am trying to parse columns information for Profile Generic object (OBIS code 1.0.98.2.0.255). And attempt to parse data from the meter throws the error:
Unable to cast object of type 'System.Byte[]' to type 'System.IConvertible'.
System.InvalidCastException: Unable to cast object of type 'System.Byte[]' to type 'System.IConvertible'.
at System.Convert.ToInt32(Object value)
at Gurux.DLMS.GXDLMSClient.UpdateObjectData(GXDLMSObject obj, ObjectType objectType, Object version, Object baseName, Object logicalName, Object accessRights)
at Gurux.DLMS.GXDLMSClient.ParseLNObjects(GXByteBuffer buff, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
at Gurux.DLMS.GXDLMSClient.ParseObjects(GXByteBuffer data, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
at Gurux.DLMS.GXDLMSClient.ParseObjects(GXByteBuffer data, Boolean onlyKnownObjects)
The request for the captured objects data looking like this:
<HDLC len="18">
<TargetAddress Value="1" />
<SourceAddress Value="20" />
<FrameType Value="32" />
<PDU>
<GetRequest>
<GetRequestNormal>
<AttributeDescriptor>
<ClassId Value="0007" />
<InstanceId Value="0100620200FF" />
<AttributeId Value="03" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
</PDU>
</HDLC>
Reposense from the meter:
<HDLC len="88">
<TargetAddress Value="20" />
<SourceAddress Value="1" />
<FrameType Value="52" />
<NextFrame Value="C401C100010F020412000809060000010000FF0F02120000020412000309060100010800FF0F02120000020412000309060100010801FF0F02120000020412000309060100010802FF0F02120000020412000309060100010803FF0F02120000020412000309060100010880FF0F021200000204120003090601000308" />
</HDLC>
Reply data, which i tried to parse: 010F020412000809060000010000FF0F02120000020412000309060100010800FF0F02120000020412000309060100010801FF0F02120000020412000309060100010802FF0F02120000020412000309060100010803FF0F02120000020412000309060100010880FF0F02120000020412000309060100030801000308
Code C#:
GXDLMSSecureClient _client = new GXDLMSSecureClient();
_client.ParseObjects(new GXByteBuffer(StringToByteArray("010F020412000809060000010000FF0F02120000020412000309060100010800FF0F02120000020412000309060100010801FF0F02120000020412000309060100010802FF0F02120000020412000309060100010803FF0F02120000020412000309060100010880FF0F02120000020412000309060100030801000308")), true);
public static byte[] StringToByteArray(string hex)
return Enumerable.Range(0, hex.Length)
.Where(x => x % 2 == 0)
.Select(x => Convert.ToByte(hex.Substring(x, 2), 16))
.ToArray();
Meter model CE308 S31
