  3. Reading a Specific OBIS Code
Reading a specific OBIS code
By xloving , 22 March, 2021
Its a follow up on https://www.gurux.fi/comment/20393#comment-20393
The obis code is present in the device and I see the read value when the whole data is read in python. Have tried few hacks but it didn't yield any fruit
Profile Generic 1.0.94.91.0.255Columns:
0.0.1.0.0.255 Clock | 1.0.12.7.0.255 Voltage | 1.0.11.7.0.255 Phase Current | 1.0.91.7.0.255 Neutral Current | 1.0.13.7.0.255 Signed Power Factor | 1.0.14.7.0.255 Frequency-Hz | 1.0.9.7.0.255 Apparent Power-VA | 1.0.1.7.0.255 Active Power-W | 1.0.1.8.0.255 Cum. Energy-Wh(Imp) | 1.0.9.8.0.255 Cum. Energy-VAh(Imp) | 1.0.1.6.0.255 MD-W(Imp) | 1.0.1.6.0.255 MD-W(Imp) | 1.0.9.6.0.255 MD-VA(Imp) | 1.0.9.6.0.255 MD-VA(Imp) | 0.0.94.91.14.255 Cum. Power On Duration | 0.0.94.91.0.255 Cumulative Tamper Count | 0.0.0.1.0.255 Cum. Billing Count | 0.0.96.2.0.255 Cum. Programming Count | 1.0.128.7.87.255 | 1.0.128.7.46.255 | 1.0.128.7.51.255 | 1.0.128.7.50.255 | 1.0.128.7.88.255 | 1.0.128.8.75.255 | 1.0.128.8.76.255 | 1.0.128.8.27.255 | 1.0.128.8.26.255 | 1.0.128.8.77.255 | 0.128.162.2.128.255 | 0.128.162.4.128.255
Entries: 0/1
-------- Reading 7 1.0.94.91.0.255 Instantaneous Profile
Entries: 1/1
03/22/21 17:58:57 |
236.74 |
0.62 |
0.62 |
-0.77 |
49.800000000000004 |
140.0 |
110.0 |
75200.0 |
92400.0 |
75 |
03/20/21 09:30 |
91 |
03/08/21 15:00 |
73748 |
1 |
3 |
0 |
01 00 00 |
00 00 00 |
00 00 00 |
00 00 00 |
00 00 00 |
18259 |
0 |
0 |
0 |
0 |
752251 |
924092 |
Sharing a screen shot for its presence in DLMSDirector as well.
5 years 4 months ago
You can read it using client example if you give -o parameter to save the association view and -g to identify the logical name.
Something like this:
-o output.xml -g 0.128.162.2.128.255:2
Or you can do it in the code like this:
obj = GXDLMSRegister("0.128.162.2.128.255")
self.read(obj, 2)
xloving
5 years 2 months ago
Really sorry for the log pause in between.
I have tried using the -g option but the result is
python main.py -S /dev/ttyUSB0 -d India -a Low -P <password> -c 32 -g "0.128.162.2.128.255:2"
gurux_dlms version: 1.0.104
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x20
Standard: Standard.INDIA
File "main.py", line 102, in main
raise Exception("Unknown logical name:" + k)
Exception: Unknown logical name:0.128.162.2.128.255
Is there a place where these codes are stored as reference ?
I see gurux_dlms/India.txt having set of codes but editing it didnt change anything
0.128.162.2.128.255 is not in the association view.
It might be that you can read only reading profile generic 1.0.94.91.0.255 and it's not planned to read 0.128.162.2.128.255 directly.
Aman Srivastava
4 years 3 months ago
I am getting same issue with
I am getting same issue with the gurux_python code.
I am using GS5500677 Genus meter and tring to read through optical port.
By simple command python3 main.py -S port No. (inside : Gurux.DLMS.Client.Example.python)
This command return me some value of meter details. but when i tried to read instantaneous or load Profile by providing -g OBIS Code, I am getting a error :-
File "main.py", line 106, in main
Exception: Unknown logical name:1.0.12.44.0.255
So for confirmation of suitable obis code i also run this on meter tool and that tool are giving me response but same obis code is not working in GURUX code.
Can you please reply soon so that I can start my work, It will be great help for me.
Aman Srivastava
Please anyone help me out.
In reply to Please anyone help me out. by Aman Srivastava
Hi Aman,
Hi Aman,
Please, create a new topic if you have a new question. I'll answer your question after that.
  • liha_2019
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
