  3. Change Deviation In Clock.Time Attribute
Change Deviation in Clock.Time attribute
By SgmUsr , 15 February, 2021
I would like to change the deviation highbyte and deviation lowbyte in the Clock.Time attribute.
The code i'm using is:
clock = GXDLMSClock()
clock.time = GXDateTime(datetime.datetime.now())
clock.timeZone = 60
clock.deviation = 60
but what it is creating is
<OctetString>
<SpecifiedLength>12</SpecifiedLength>
<Contents>07E5020F010B091002FFC400</Contents>
</OctetString>
with FFC4 as deviation. In this field we use 003C.
How can I change these fields?
5 years 9 months ago
Your meter is using UTC time zone and not the DLMS standard time zone. You need to set useUtc2NormalTime for the client.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
cl = GXDLMSClient()
cl.useUtc2NormalTime = True
SgmUsr
Thank you, it works fine.
Thank you,
it works fine.
The date-time is causing a lot of problems. :-(
Some meters expect that ms is not used and some that it is zero.
This deviation is also causing problems...
