  3. Profile Generic All, Memory Allocation Fail
Profile Generic All, Memory Allocation fail
By Vishal Patel , 11 February, 2021
I'm using ANSI C Library.
When reading Profile Generic ALL entry for below mention obis code, getting below mentioned error from ANSI C library.
ProfileGeneric 1.0.99.1.0.255:2
read entry: ALL
Getting below error after few responses from meter (sometime after 150 meter responses, and sometime after 15-20 meter responses):
"ReadObject failed ProfileGeneric 1.0.99.1.0.255:2 Not enough memory available."
Can you plz provide me helpful details?
Vishal
5 years 5 months ago
Hi Vishal,
Hi Vishal,
Don't read all data from the buffer at once. You don't have enough memory.
You need to read one day or sometimes one hour at a time. This depends on the profile generic and how many capture objects (columns) there are and how much memory you have available.
You can try to read data with cl_readRowsByEntry or cl_readRowsByRange.
You need to save date-time from the last row and give it to the start time to cl_readRowsByRange.
Set end-time to start time + 1 hour.
  • liha_2019
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
