  3. Integration TCP/UDP Using GPRS On Arduino Server.ino
Integration TCP/UDP using GPRS on Arduino server.ino
By SmartRaysam , 3 February, 2021
am trying to integrate TCP using the GSM module in Arduino server.ino for connectivity to the client using dynamic or static ip.
what is the procedure I need to follow for the integration?
5 years 6 months ago
You need to add Auto connect object. Then you need to add destinations where you want to connect. Check example from here:
https://github.com/Gurux/GuruxDLMS.c/blob/b9d1fc53e94270d2bd7150d12df8a…
svr_preAction is invoked when you need to make the connection and you need to handle it there.
SmartRaysam
SmartRaysam
5 years 5 months ago
hi, still on using GSM module
thanks
  • CRISTIAN MAXENTI
  • mPDxPIQgXwPXoV…
  • AaronAcecy
  • lin
  • JFaHTYnuOHYICbRfEZ
