  3. Activity Calendar - Unmatched Type
Activity Calendar - unmatched type
By Remith , 25 January, 2021
I am facing below issue while writing Activity calendar- Passive day profile to the meter.
gurux.dlms.GXDLMSException: Access Error : Device reports a unmatched type.
----------CODE---------------------
GXDLMSActivityCalendar ac = new GXDLMSActivityCalendar(OBIS_ACTIVITY_CALENDAR);
com.readObject(ac, INDEX_PASSIVE_DAY_PROFILE_TABLE); //Reading index data
ac.setDayProfileTablePassive(new GXDLMSDayProfile[] {dp});
com.writeObject(ac, INDEX_PASSIVE_DAY_PROFILE_TABLE); // Writing Day Profile
----------TRACE DECRYPTED---------------------
Reading Passive Day Profile
TX: C0 01 C1 00 14 00 00 0D 00 00 FF 09 00
RX: C4 01 C1 00 01 01 02 02 11 01 01 03 02 03 09 04 02 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 16 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
Writing Day Profile
TX: C1 01 C1 00 14 00 00 0D 00 00 FF 09 00 01 01 02 02 11 01 01 03 02 03 09 04 02 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 16 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
RX: C5 01 C1 0C
Kindly do the needful...
Thanks & Regards
REMITH
5 years 9 months ago
There is nothing that we can do about this. I checked the bytes and everything is correct.
This is a meter issue.
If you compare read and write trace you will notest that the payload is the same. I believe that you have read and try to write the same data. Ask the meter manufacturer to fix it.
Remith
Thank you Mikko.. I will
Thank you Mikko.. I will contat the manufacturere team.
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
