  3. Problem In Security
problem in security
By Varun Sharma , 13 January, 2021
Hello sir
Previously code was working fine but when i updated some files like "Gurux.Dlms,Gurux.Common,Gurux.Serial" and then try to rebuild the code it is showing error in below line
GXDLMSSecureClient dlmsClient = new GXDLMSSecureClient()
dlmsClient.Ciphering.Security = Security.None;
Error: Severity Code Description Project File Line Suppression State
Error CS0266 Cannot implicitly convert type 'Gurux.DLMS.Enums.Security' to 'byte'. An explicit conversion exists (are you missing a cast?) Gurux Testing D:\Gurux Testing Part1 SmartServer V1.0\Gurux Testing\PushListener.cs 559 Active
5 years 8 months ago
You need to change to this:
dlmsClient.Ciphering.Security = (byte) Security.None;
Varun Sharma
Thaanks You(Solved)
Thaanks You(Solved)
  • lh
