  3. Communicating With Secure Saral Over DLMS Using Pyhon
Communicating with Secure Saral over DLMS using pyhon
By anildhyani82 , 25 December, 2020
Gurux.Serial
I am trying to communicate with Secure Saral meter using Gurux client library . Interface used is Serial.
Mikro Usb on Meter to Db9. Parameters i used are following:
a) Server Address : 3
b) Client Address : 32
c) Password : ABCD0001
d) Type of Addressing : Logical
e) Logical Server : 1
f) Authentication Type : Low
Tried with different possible combinations but no success.
It tries to send SNRM packet and gets failed over there. Basically timeout happens . So i am not sure why this is happening. Has any one worked / communicated with this meter.
GXDLMSDirector 8.1.2012.1701
Log created 20:09:40
20:09:44 Initializing serial connection.
20:09:44 08:09:44.366 Info Opening
20:09:44 08:09:44.366 Info Serial Port Settings: Port Name: COM4 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Flow Control: None Eop: None
20:09:44 08:09:44.369 Info Open
20:09:45 Send SNRM request.
7E A0 08 02 03 23 93 36 54 7E
20:09:45 08:09:45.370 Sent 7E A0 08 02 03 23 93 36 54 7E
20:09:45 08:09:45.384 Received 7E A0 08 02 03 23 93 36 54 7E
I have tried using DLMS director GUI utility also but results are same.
Looking for some valuable inputs.
5 years 6 months ago
Try to change server address to 1. You are receiving an echo from the serial port. Check also your serial port settings from the meter documentation.
Vamsidhara Reddy
2 years 3 months ago
Hi Anil, Where you able to…
Hi Anil,
Where you able to connect to the Saral meter if yes let me know which DB9 connector you used.
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
