  3. Trouble Reading ISKRA MT880
Trouble reading ISKRA MT880
Profile picture for user luca.fallabrino
By luca.fallabrino , 16 December, 2020
Hi, i need to read data from Iskra MT-880 using GSM connection.
I use a python command-line program which can read several models already (MT830, MT860, TE-851) as well as other manufacturers.
I can't get beyond the identification /?! command. Here are some example :
DEBUG: __sendRawBytes, sending: ATD{SIM_NUMBER}
DEBUG: commandAndStdResult: buffer =
CONNECT 9600
DEBUG: dlms: reconfigure serial port bytesize:7, parity:E
DEBUG: ISKRA: handshake 68797367 //Serial number of meter
DEBUG: __sendRawBytes, sending: /?68797367!
DEBUG: dlms: identify_meter None
ERROR: 'Unable to identify meter 68797367, no response'
DEBUG: dlms: reconfigure serial port bytesize:8, parity:N
DEBUG: SimGsm quitDataMode 0
DEBUG: __sendRawBytes, sending: +++
DEBUG: SimGsm hangUp 0
DEBUG: executing command 'ATH'
DEBUG: __sendRawBytes, sending: ATH // Hang up call
DEBUG: commandAndStdResult: buffer =OK
I tried sending some NUL chars (usually 8) and wait 500 msec before sending the command - It worked on Iskra MT860 meters. But not here.
Of course che command is followed by \r\n (not shown in logs.)
Do you know any way to do it ? The manual say that meter supports IEC 62056-21 mode C protocol.
Best regards, and thanks for any useful hint.
Luca
5 years 11 months ago
Hi Luca,
Hi Luca,
We haven't use IEC 62056-21 mode C when reading MT-880 over the GSM. We are always using DLMS and I don't know if that possible. IEC 62056-21 mode C is supported when you communicate with the optical probe. I'm afraid that you need to ask this from the meter vendor.
Arnold Kuntner
5 years 3 months ago
Hi Luca,
Hi Luca,
have you been able to solve the problem reading the MT-880 over GSM. I'm trying it too, but I can't find out how to make the identification.
Many thanks,
Arnold
