  3. Arduino Client Example
Arduino client example
By Toni , 23 November, 2020
Hi Everyone,
I am trying to use the Arduino client example, the code compiles, but readings via serial monitor prints jargons, I am on the same 9600 baudrate as set in the code. I also changed to 115200 baudrate, but still the jargons on serial. Any one facing this?
I am using the latest commit from GitHub
Toni
6 years ago
I am running on an Arduino
I am running on an Arduino Mega
5 years 12 months ago
What meter do you try to read? Are you using an optical probe or serial port?
Toni
I am using serial1, which is
I am using serial1, which is connected to HC-05 paired to optical Probe VIA Bluetooth.
In summary, I am trying to read a HEXING meter using optical Probe.
There are several things that might cause problems. Try to connect your optical probe to your PC and read your meter with GXDLMSDirector. It's the easiest way to get started.
Toni
That has been done already, I
That has been done already, I can communicate via GXDLMSDirector using the optical Probe. I send an image of what I am receiving from the serial monitor.
Please, don't send the image. Send a text what you are receiving. Pictures are compressed and they are hard to read.
Toni
Here is the response I get from the serial output. The baud rate is the same 9600.
Toni
That is non-ASCII data. Try to get it as a hex string.
